relay problem
Old Sep 11, 2005 | 09:48 AM
mtttricker's Avatar
mtttricker
relay problem
Hi ,I have been looking at some old posts and found close to the same problem . I have a 1989 econoline 150 5.0 302 .I am not getting full power to the pump relay or the eec relay when I turn to start the feul pump or check engine light does not come onbut brake light does and it turns over if I jump a wire from battery to the pump or eec relay check engine light comes on and it starts up and runs but if I pull the jump wire it kills the engine I traced the wire and they are going into eec I can not find any shorts any suggestions would be a great help thanks Mtttricker
