ashtray removal
Old Sep 10, 2005 | 10:01 PM
goatdriver's Avatar
goatdriver
ashtray removal
I am still trying to find out where my rattle in the ashtray is coming from. Can anyone tell me how to remove it? I think a wire or something is banging up against it inside, and I want to pull it out to check.
Old Sep 11, 2005 | 07:51 PM
FS-150's Avatar
FS-150
This thread may help.
https://www.ford-trucks.com/forums/s...ht=dash+rattle
Chris Adams post may hold the fix for you.
Hope this helps.
Old Sep 13, 2005 | 12:17 PM
TNYARDBIRD's Avatar
TNYARDBIRD
I also have a problem with a clicking noise coming from under the dash on drivers side, sounds like two rods pecking together, drives me crazy. I've tried to find the problem myself, taped every thing up I thought might be the problem, drive & there it is again. Took to the dealer twice, but couldn't the sound to reproduce during test drive with tech or the service manager. I read the thread above and going try to fix tonight. I'm at the point of getting rid of it if I can't fix it. hope this works
Old Sep 13, 2005 | 12:36 PM
Dazz's Avatar
Dazz
Ashtray
From Chris Adams post:
"I removed the cupholder-ashtray . Remove two 10 mm screws, then struggle to pull it out."
Am I correct in believing that you pull the radio trim off to get at the 10mm screws?
Anyone got a simple, but functional idea what to do with the space that would remain if one pulled the cupholder-ashtray and cigarrette lighter?
Old Sep 13, 2005 | 01:00 PM
ChrisAdams's Avatar
ChrisAdams
Several guys have put head units in that space. On my truck I have the airbag disable in there and so it wouldn't work out well. I have added a door lock switch, and the red LED for the Alarm.
On the trucks with the storage space, that would be a cool place to mount something like a DVD.
Two low down for gauges, though, at least the storage space is.
I sometime use the drink holder, or I would put something in there..
Chris
Old Sep 13, 2005 | 01:19 PM
Dazz's Avatar
Dazz
Quote from Chris Adams:
"Several guys have put head units in that space. On my truck I have the airbag disable in there and so it wouldn't work out well. I have added a door lock switch, and the red LED for the Alarm."
Being a Navy guy I am not sure having a head in the middle of the dash would be acceptable to my passenger .
I do know what you mean. I am satisfied with my 6-DVD stock player, so more music goodies is not a must.
I too added an alarm system. I was hestant as previously on my '93 the alarm company installed my flashing red light where the steering assembly blocked its view from the passenger side. I had to rewire a second red flasshing light to the passendger side of the steering column. On my '93 it had to be wired paralell (loop) to get it to work. On my current '04 the alarm came with a small but magnified lens blue light that lights up approx ¾ of the cab with each flash. Add this to the key code red flashing light and most thieves will be warned away.
How about an ATM machine where the ash tray goes? Would save trips to the bank.
Old Sep 13, 2005 | 01:52 PM
ChrisAdams's Avatar
ChrisAdams
Navigation stuff might fit nicely in that gap.
I put in the Ford Deluxe Alarm/Keyless, and the red light is about right, not too bright, but noticable if you look in the window.
The lock switch is a regular 2004 F150 drivers door lock switch, as my STX didn't come with locks.
Yeah, my typing has a lot of typos, lately, but it will get better when I get the thingie that holds my fingers together off.
Chris
Headed for the Beach for a week or so!!!
