Suspension Question
Old Sep 9, 2005 | 10:36 AM
Snowman671's Avatar
Snowman671
Suspension Question
Guys,
My truck was lifted when i bought it. I bought new front springs (Stock) and shocks. My question is in the rear . it had 3" blocks in it. I removed them now the truck sits too low in the back did the 79 come with 1" or 1 1/2" blocks from the factory? the truck looks like it has reverse rake now and i need to fix it. should i just put 1 1/2" blocks back in or is it a spring issue in the rear.
thanks
Old Sep 9, 2005 | 11:45 AM
1975Ford's Avatar
1975Ford
The original block is about 3" in height and has a flange that stick out on one side. I would pull a used block off a 73-79 4 wheel drive.
Old Sep 9, 2005 | 12:14 PM
Snowman671's Avatar
Snowman671
Damn, does the 79 4x4 sit that much higher in the back from the factory? I have them blocks the 3" with the flange that is what i took out.. I guess i better go get some new U-BOLTS made and put them back in.
BTW. If anyone has trouble getting u-bolts I can have them custom made for like $ 8.00 each
Old Sep 9, 2005 | 01:43 PM
1975Ford's Avatar
1975Ford
Yes, the original sit much lower in the front. "Skyjacker" make 2" lift front coils for the front suspension. or might give "Bronco Graveyard" a look also. I think a 2" lift coil might level your truck out.
Thats good to know, I'll add this to my personal buddy list.
Thanks.
