Identification ford 289
Old Sep 9, 2005 | 10:02 AM
Mats Nilsson's Avatar
Mats Nilsson
Hi!
I use a ford 289 in my old truck. Can you help me out here with identification.
The casting number near the starter reads C5AE-6015E. 1965 I suppose but can you tell me what kind of car the engine came from. It's a lot easier for me to get parts if I know some history. Thanks a lot! I hope you understand most of my Swenglish.
Mats Nilsson, Sweden
Old Sep 9, 2005 | 07:05 PM
TigerDan's Avatar
TigerDan
Hej, Mats! Den där er ingen problem för mig, Jag kanna förstå du.
I'll stick to English now for the benefit of our other users, and because my Swedish is nowhere near as good as your English!
Unfortunately, we can't tell from the casting number alone what vehicle that engine originally came in. Yes, the first 2 digits, C5, stand for 1965, the A stands for the Ford Galaxie, but that's the car that the small block Ford engine was originally designed for, not necessarily the exact car that your engine came in. The E stands for the engine department of Ford Engineering. The next group of digits, 6015, is the number that tells us the part is an engine block (as if we couldn't tell that by looking at it!) I think the second E, the one after the block number, denotes a design change. Does your 289 have 5 bolts that hold the engine to the bellhousing, or transmission, or does it have 6?
Old Sep 10, 2005 | 08:01 AM
Mats Nilsson
Hi!
It have 6 bolts. I found a small sign next to the casting numbers. It reads 7E4 and it's attatched to the engine block with two small screws.
The casting number on the tranny ( C4) are C6 AP-T0027-C.
Thanks a lot!!!!!!!!
Mats
Old Sep 10, 2005 | 10:34 AM
TigerDan's Avatar
TigerDan
6 bolts...that's what I thought. That 7E4 is your date code, it tells us exactly when the block was cast. 7E4 breaks down to May 4th, 1967. Even though the casting number of your block was C5, that just indicates when that particular design revision was put into production.
Unfortunately, the casting number and date codes still don't tell us what vehicle the engine originally came in. That information was on a small metal tag that was attached to the top of the engine, held on by one of the coil bolts. I'd be surprised if that tag is still there.
Does your engine still use the factory intake manifold, and is it 2-barrel or 4-barrel ?
The transmission numbers don't really help us either.
But as for getting parts, in 1967 the 289 was available in several different vehicles with very few changes between them. If you said that it came from a '67 Mustang, that would probably get you the right parts.
Old Sep 10, 2005 | 12:14 PM
Mats Nilsson
I'm really pleased with the answer even if I dont know what car the engine came in. The intake manifold is an original for 2-barrel carburetors. The casting numbers on it starts with C5 but there are no metal tag on the engine. Anyway, I thought it was from 1965 but now I know and that makes it easier. Thanks a lot, I really appreciate the help from you!!!!
Mats Nilsson
Kiruna, Sweden
Old Sep 10, 2005 | 12:26 PM
TigerDan's Avatar
TigerDan
No problem, Mats. Glad to help!
