8.8 with discs?
Old Sep 9, 2005 | 08:42 AM
mikeyswood's Avatar
mikeyswood
8.8 with discs?
Did any 8.8 come with factory discs for the 150?
Thanks,
Mike
Old Sep 9, 2005 | 11:08 AM
subford's Avatar
subford
Thanks,
Mike
Yes they did, brakes and LS both had discs, on the breaks I do not know what year they started but 2001 and up had them.
Old Sep 9, 2005 | 03:42 PM
mikeyswood's Avatar
mikeyswood
Thanks,
Can I bolt a 2001-up to a 94?
Old Sep 9, 2005 | 07:17 PM
andym's Avatar
andym
I believe the spring perches are in different locations. If you can weld/grind, that shouldn't be a problem.
You will need to carry two spare tires and run two different style wheels - the bolt pattern will be different between the front and rear.
You would also need to take out the booster, master cylinder and proportioning valve from the newer truck and put it in the older truck.
Then - I'm not sure the ABS connectors are compatible. My guess is that you will lose your ABS.
What you want to do is get a rear disc conversion kit from Jeff's Bronco Graveyard. You won't run into these issues.
Old Sep 9, 2005 | 09:59 PM
subford's Avatar
subford
Thanks,
I will get back with you tomorrow. I have a 2001 out in the barn. I'll go out and do some measuring on both and get back with you.
Old Sep 10, 2005 | 10:49 AM
subford's Avatar
subford
Thanks,
NO
King Bolt hole to king bolt hole over the center, approximately = 2001 47" - 1994 44 1/2"
Flange to flange = 2001 61 1/2" - 1994 60 1/2"
Sorry.
Old Sep 10, 2005 | 01:50 PM
4dzilla's Avatar
4dzilla
I believe you'd have to find one from a 4x2 though. I think all of the 4x4's got the 9.75. Could be mistaken though.
Old Sep 11, 2005 | 09:38 PM
Ponyracer's Avatar
Ponyracer
Thanks,
Mike
My answer is no. The disc brakes came on the 97- 9.75" F150, LD F250 and Expeditions. The 8.8 came in the 87-88 Turbo Thunderbirds, 94- Mustangs and 95- Explorers with disc. The other problem that was stated is the the bolt patterns are different from 96 to the 97 year. The 97 and up LD trucks have a metric bolt pattern. You can get a rear disc setup from a 9" or 8.8" diff and add it to your 8.8 then you need a proportioning valve and a correct brake master cylinder.
Old Sep 12, 2005 | 03:32 AM
mikeyswood's Avatar
mikeyswood
Thank you all very much!!
Mike
Old Sep 12, 2005 | 12:27 PM
Boss_358's Avatar
Boss_358
The 4.6 F-150's all have 8.8's 4WD or 2WD. 5.4 trucks have the 9.75. I think its still that way to this day. Go to a dealership, find a 4x4 truck with a 4.6 and look at the rear axle. Chances are its an 8.8.
