Help with performance problem, please.
Old Sep 8, 2005 | 11:24 PM
packrat56's Avatar
packrat56
73' 302, C4, about a year ago it got fresh heads and pistons, new 2bbl holly, electronic ign conversion (drop in unit, into old dizzy) Plugs and wires...
Electric fan about a month ago...
Ran well for about a year. Now it idles very poorly (never had a great idle, but now its very poor)
When I take off it cuts out pretty badly for quite a while, at higher rpm its stronger, but seems to be still missing.
When I thumb the throttle it responds great, but in normal driving pretty badly.
I have looked for vac leaks, looked and listened so far.
Cleaned the cap and rotor.
Checked a plug, nice grey ash, pretty clean, bit pink on the cone.
Double checked fuel flow (filters full)
Turned up the idle mixture to see the reaction; stronger at idle, still missing bad..
Can an alternator (with the stress of the new electric fan) begin to seaze up and still show a strong charging on the gauge?
Pertronix unit, can it fail and still run, just poorly?
ANY and ALL ideas appreciated, Im lost...
Old Sep 9, 2005 | 10:37 AM
Kemicalburns's Avatar
Kemicalburns
first would be a tune up. new plugs,cap/rotor and possibly wires if they are old. check your timing it should be 8*-10* btdc. you might also do a compression test as well .
to check for vacum leaks spray carb cleaner around the intake etc.. if the idle increases then you have a leak. might even replace the fuel filter
Old Sep 9, 2005 | 10:43 AM
Terran's Avatar
Terran
Yeah definantly check your timing, hell for kicks make sure your firing order is right.
Old Sep 9, 2005 | 02:53 PM
ronclark's Avatar
ronclark
Try isolating the miss to determine what cylinder it is. Pull the plug wires off one at a time to determine which cylinder is missing. It the miss seems to be moving around to different cylinders or just a partial miss on more than one cylinder then it's probably a vacumn leak/carb problem. Otherwise check compression, wires, plugs on the missing cylinder. If it has egr make sure the egr isn't sticking open. Check timing with a light and make sure vacumn and mechanical advance is working correctly.
Old Sep 9, 2005 | 05:28 PM
packrat56's Avatar
packrat56
Thanks for all the leads, I will check out all of them. Is it OK to pull the leads off the plugs while it is running? Or am I in for a shock if I do that?
Old Sep 9, 2005 | 06:26 PM
cjjeeper85's Avatar
cjjeeper85
Its alright to do that, just watch out they bite.
Old Sep 9, 2005 | 06:51 PM
TigerDan's Avatar
TigerDan
Check the power valve in that Holley.
Gatopescado
Oct 21, 2014 02:19 PM
2001supercrewf150
Modular V8 (4.6L, 5.4L)
Mar 25, 2010 04:23 PM
Aeronut
Aerostar
25
Dec 22, 2005 05:19 PM
ahall8
1997 - 2003 F150
Jun 20, 2005 09:29 PM
niteowl
19
Dec 1, 2003 09:20 PM
