Exhaust Pressure Sensor
Old Sep 7, 2005 | 11:53 AM
rwhalen3's Avatar
rwhalen3
I've had some problems with my 03 F-250 6.0 PSD that many of you are writing about. Mine loses power, coughs out black smoke, and the turbo wistle cuts in and out, no check engine coming on at all. I talked to 3 stealerships and the last one says its the exhaust pressure sensor. He says it's a nationwide problem and the EPS sensors are all backordered. I hope this information will help some of you isolate your problems and get your trucks back up and running soon.
Old Sep 7, 2005 | 04:43 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
rwhalen3
Welcome to FTE.
Check out our Guidelines:
https://www.ford-trucks.com/guidelines.html
And the Read First: notices at the top of each forum, it will help you understand and navigate FTE easier.
Indeed you are correct, there are quite a few issues revolving around the Exhaust Pressure Sensor
BigF350<o =""></o>
