Sponsored by: Kumho
doubling up on add a leafs
Old Sep 6, 2005 | 11:12 PM
jad4's Avatar
jad4
I am almost ready to tear into my rear suspension and I want some advice. I have two sets of rough country add a leafs and was planning on just putting two leaves per side and taking out the two larger leafs on the original pack. Is there any danger in this? I realize that it is an experiment but I think it should work and may give me 2-3 inches of lift as one set is supposed to give 1.5 inches.
thanks, Jeff
Old Sep 7, 2005 | 12:17 AM
ivanribic's Avatar
ivanribic
There's no danger to it Jeff, just an extra rough ride. If you can live with that it'll work just fine. Make sure your u-bolts are long enough or get a new set made.
Old Sep 7, 2005 | 01:39 PM
jad4's Avatar
jad4
I won't mind the rough ride. I am thinking about shortening up the bottom add a leaf a few inches so it looks like a normal pack. If I do that do you think it will improve the ride at all or should I not even bother?
Old Sep 7, 2005 | 09:06 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Hey Ivan, don't us Montana folk have some strange ideas?
Jeff, I don't think your math is correct on the 1.5"+1.5" add-a-leafs. If both leaf packs are the same, you'll net more than 1.5", but methinks you'll end up with just slightly more than 1.5", say 1.75".
Cody
Old Sep 8, 2005 | 11:45 AM
jad4's Avatar
jad4
Yeah, I don't know what the final lift will be. Probably somewhere around two maybe more, maybe less. I'll measure when i get around to doing it and I will let you know.
jeff
