differential swap
Old Sep 6, 2005 | 05:15 PM
tunruh's Avatar
tunruh
differential swap
Does the rear differential have to match the front on a 4x4. I have a 79 F-350 with a great rear end ( about a 4.11) and want to put it on my 93 F-250 4x4.
Old Sep 6, 2005 | 05:32 PM
subford's Avatar
subford
Well yes but, Ford used to put the 4.11:1 in the front and a 4.10:1 in the back through 1970's and some where after that I think they started putting the same at both ends. I have never heard of a 4.11:1 in the rear end and it will not work at all if you have a 4.10:1 in the front, and it would tear your truck up on dry pavement.
Old Sep 6, 2005 | 05:41 PM
tunruh's Avatar
tunruh
ok, I'm guessing the rear is in the 4.10 range. the front and rear of the 93 are in the 3.90 range.
Old Sep 6, 2005 | 09:42 PM
subford's Avatar
subford
A 4.10 or about will not work as it would buck up in the middle and may bend the frame.
