Sponsored by: Real Truck
sway bar end links
Old Sep 6, 2005 | 11:58 AM
chriswickson's Avatar
chriswickson
sway bar end links
Does anyone know how to press out or remove the steel bushings from inside the sway bar end links on a 2002 F-350? The existing bushings at two of the ends are a bit larger than the mounting bolt shaft and they slap back and forth as the suspension flexes. I will be replacing the end grommets as part of the maintenance. Also, advice for reinstalling the bushings would obviously help too. Thanks for the help.
Chris Wickson
2002 F-350 PSD
Old Sep 6, 2005 | 04:29 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Sep 6, 2005 | 04:35 PM
wolfbike1500's Avatar
wolfbike1500
The bushings in the end links are not replaceable. You just buy the whole link, bushings and all. It's not too expensive, so don't worry about that! You should replace the bushings that hold the sway bar to the axle while you are at it.
99-F350 Lariat V-10 CC LB SRW
Old Sep 7, 2005 | 12:56 AM
3/4ER's Avatar
3/4ER
You can also go with polyurethane replacement bushings, they come with new sleeves.
Old Sep 7, 2006 | 08:44 PM
IBDJ's Avatar
IBDJ
Question endlink bushing removal, F350
I just got some poly bushings for the front and rear sway bars on my 03 F350. I pulled one of the endlinks only to find the stock bushings impossible to remove (with simple shop tools). I'm betting they have to be pressed out. Can anyone confirm this?
Old Sep 7, 2006 | 08:51 PM
super 6.8's Avatar
super 6.8
There was a TSB that replaced the bushings on the front sway bar with new spherical bushings. If you buy new ones be sure and ask about that. They are far better than the ones they replaced. I had my 99 done about 3-4 years ago.
Old Sep 7, 2006 | 08:54 PM
2002 F350V10's Avatar
2002 F350V10
If you were to replace them with poly bushings the easy way to remove the old ones would be with heat from a cutting torch. (obviously off the vehicle). It would just burn the rubber out.
Old Sep 7, 2006 | 09:30 PM
IBDJ's Avatar
IBDJ
Torch looks like it would work with the rear (they are rubber), but the front seams like it has a steel outer sleave.
Old Sep 7, 2006 | 09:41 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
i have ONE good stock endlink for the stock suspension. when i put my lift on, i used longer links, and i found that the right one had a bad bushing, the source of my clunk sound. you are free to have the good endlink if you so desire.
Old Sep 7, 2006 | 09:47 PM
IBDJ's Avatar
IBDJ
Appreciate the offer, but I want to go polyurethane. I've heard it helps out with reducing sway - I'm putting a camper on the back. My last truck was a bit sketchy in that department, so I'm trying to upgrade my newer truck, before I put the camper on it.
Old Sep 26, 2006 | 04:40 PM
OceanTrvlr's Avatar
OceanTrvlr
I just did new end-link bushings the other day. I had to crank the **** out of them on a 10-ton press to get the metal-lined bushings to pop out. It was NOT easy and would never happen simply by banging on them or using a clamp. A hydraulic press seems to be the only way I could see them coming out. The new Energy Suspension bushings pressed in very easily. The clunk is gone...
Ethan
2002 F-250
Sea Tow - Green Harbor, MA
