Running rough (missing)
Old Sep 5, 2005 | 10:58 AM
new2novas's Avatar
new2novas
Heres the situation i got goin on
I have had this miss in my 83 f150 300I6, single barrel , for quite some time now, i don't drive it every day so it isn't utmost importance, but i need help bad. I tried replacing the cap, rotor, plugs, wires, module (duraspark), carb...and i am lost, so i figured i would see maybe if there was a suspect cylinder by removing plug wires. Take number 3 off, doesn't seem any different, so i try 5, wow wierd still seems the same, so i take off number 6 wire, little bit different, but not 3 cylinders down different. so i take one more off, the thing still runs and responds to throttle, but is finally clearly missing 4 out of 6 cylinder....i am scared to pull them all can anyone help with this demon beast....I am going to do a compression test somtime today, so i'll report back with some results on that
<!-- / message --><!-- sig -->
Old Sep 5, 2005 | 03:02 PM
new2novas's Avatar
new2novas
okay heres the compression test and plug visuals
1- 125 carboned up on one side, normal on other (yeah wierd i know, also oiled up)
2- 130 plug normal
3- 140 plug looked abnormally normal (brand new looking)
4- 135 really carboned up, oiled up, no external oil leak....rings??
5-135 slighly carbon fouled
6- 130 plug normal
other than 1 being slighlt low i don't think its a major cause for concern...
Old Sep 5, 2005 | 03:37 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
txchl33
2009 - 2014 F150
Jul 26, 2013 10:37 AM
F250FarmBoy
Engine Swaps
13
Mar 21, 2011 03:21 PM
Duke58f100
Apr 11, 2009 05:20 PM
John311t
65
Aug 17, 2008 12:52 AM
Brians97F250Crew
6.4L Power Stroke Diesel
Feb 8, 2006 03:38 AM
