themostat
Old Sep 5, 2005 | 09:13 AM
magnum300's Avatar
magnum300
themostat
Replacing upper hose and a 203 t stat, is there a trick to getting old t stat out mines really in there
Old Sep 5, 2005 | 09:16 AM
mueckster's Avatar
mueckster
Just grab it with some pliers. Twist and pull. Also, put a light bead of silicone on the hose neck where it bolts on. They tend to warp and seep, even with a new O-ring.
Old Sep 5, 2005 | 09:17 AM
magnum300's Avatar
magnum300
i will give it a try thanks
Old Sep 5, 2005 | 11:14 AM
RobertJohn's Avatar
RobertJohn
In all likelyhod you'll need a new upper theorm. housing, the old ones corrode and aren't worth putting back on.
I cleaned mine three times and finally just got a new one, no problems then.
Old Sep 5, 2005 | 04:56 PM
magnum300's Avatar
magnum300
already had a billet aluminum housing from dieselsite.com to put on
