Sponsored by: Auxito
E-fan question
Old Sep 4, 2005 | 10:13 PM
checkyoursix's Avatar
checkyoursix
E-fan question
I want to install electric fans in my 01 screw. How much air flow do I need. I would like to do just one fan but the only kits I have seen for it are duals. I will be towing with it once in a while.
Old Sep 5, 2005 | 10:08 AM
lariat97's Avatar
lariat97
I have the Efan kit from ****** performance. It has 2-16 inch fans. It works great & actually helped my gas mileage. A friend has a fan from a Crown vic on his Lightning. It seems to work well.
Old Sep 5, 2005 | 07:21 PM
bradk's Avatar
bradk
I went with one 2800cfm 16inch fan it worked ok except when towing or off road so I added another 1500cfm 14inch and every thing is ok. I also learned the hard way not to set the fan limit off the stock guage. Go with an aftermarket one there cheap insurance.
Old Sep 5, 2005 | 10:56 PM
checkyoursix
Is the aftermarket kit pretty easy to install? Do you think two 14" fans will work? I don't want to have any problems, but I also don't want to spend $400 for the set up. Maybe underdrive pulleys would be a better option.
