Figuring out components
Old Sep 4, 2005 | 12:14 AM
matts156's Avatar
matts156
I need to get a factory service manual, but in the meantime I'd like to figure out what some of the components and capped connectors under the hood are.
Could some of you please look at my gallery and tell me what the various components/connectors are for? Thanks, I appreciate any help.
Old Sep 4, 2005 | 06:02 AM
PLC7.3's Avatar
PLC7.3
#1 is the BARO it tells the PCM what altitude your at and adjusts the shift schedule to work with the decreased power of the engine, so the trans does burn up.
#2 is the VIP connector that's where codes are taken from which the trans has set.
#3...................
#4...................
#5 is the "Tuna Can" or the low vacuum sensor for the vacuum system.
