peter1979
Old Sep 3, 2005 | 11:11 AM
peter1979's Avatar
peter1979
Question peter1979
Hello I have a 1992 ford f150 2wd that the speedometer doesn't work and the trany won't shift. I have to shift down to 1st and then go through gears. yes it is a automatic. Ive already changed the sensor on the rear end and it didn't help. Any ideas would be appreciated.Thank for the help
Old Sep 3, 2005 | 04:45 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
moved and member notified
Old Sep 3, 2005 | 05:27 PM
Popa Tim's Avatar
Popa Tim
Hi Pete,
Welcome to the Best Ford forum there is.
Your problem sounds like a bad Speedo, it sends the speed data to the computer which controls the tranny. You can take the gauge panel apart and check for voltages and reseat connectors but if that doesn't take care of it, pull another speedo from a junkyard vehicle. Hopefully its just a loose connector.
This article in the tech section should help with disassembly.
https://www.ford-trucks.com/article/...Or_Bronco.html
Cheers,
Popa TIm
