Points.. Condesor.. Oh boy.
Old Sep 2, 2005 | 11:37 PM
MacOffutt's Avatar
MacOffutt
Ok. This is going to sound extremely crazy, but I need help installing the points & condensor back in my 68. Now before anyone says take old out and put new right in same spot, I had but the Petronix kit in like 4 years ago an it just recently burnt up on me. I went to go get a new kit but the one they seel in NE is like 140 dollars or somethin like that and I just need it running to take it to a shop to get my 9" put in, so I just got a set of points and a condensor, but looking at the distributor I was completely lost. And now Im in Japan. Oo
When I looked at my chiltons the image wasnt so good and the directions didnt help much themselves. Anyone can help me with that possibly? Such as a picture?
Mac - Okinawa
Old Sep 3, 2005 | 09:32 AM
jor's Avatar
jor
Here's the best one I have. I made the photo large but with low quality to stay within the 100K attachment limit. Hope it helps.
jor
Old Sep 3, 2005 | 12:18 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
And many people claim the haven't had a problem with Pertronix units, two failed with me that's why I carried points in the glove box. Sorry to hear about your failure, just proves again a product that has many failures. Later when you have time look at Crane's XR 700 or better the XR 3000 ignition systems.
.....=o&o>.....
Old Sep 4, 2005 | 03:49 AM
ford390gashog's Avatar
ford390gashog
did you save the plate the points and condensor mount on when i did my conversion i had to remove them.
Old Sep 4, 2005 | 04:45 AM
Torque1st's Avatar
Torque1st
Posting Legend
Jor, that picture was too big, fixed
Old Sep 4, 2005 | 08:46 AM
fordloverf2501970's Avatar
fordloverf2501970
the 140 dollar is probley the pertonix 2, the earlier one is available on ebay for 35 bucks. i also carry a extra set of points and condensers as well as a extra coil and waterpump, and i used to have a extra alt and a extra starter too.. my bed toolbox is getting light got to go to oreillys and restock it lol
Old Sep 4, 2005 | 08:53 AM
texans's Avatar
texans
hey if you just need a quick temp fix. you can take the points off and files them with a small triangle file, if the problem is that they are burned up. then use a filler gague and reset them. I dont know what the spec is, but something like .005-.007 I think will work. It wont last long, but it will get you running for a bit.
Old Sep 4, 2005 | 05:53 PM
jor's Avatar
jor
Thanks, Torqu1st. That one got away from me!
Hey, Fordlover, why not just throw a whole darn engine back there!!!
jor
Old Sep 5, 2005 | 10:03 AM
fordloverf2501970
ya know for awhile last summer i almost had one. i had a extra set of heads and crank, and a power steering gear box and pump. not to meation all the electrical stuff as well as a dizzy. Had so many parts i finally tore down my 360 and turned it into a 390. Of course that had to be done because of another reason which is a different story
Old Sep 5, 2005 | 10:59 AM
MacOffutt's Avatar
MacOffutt
Hey thanks for the help. I sent this page to my buddy whos back home workin on the truck for me. Lots of help!
Old Sep 6, 2005 | 11:00 AM
fitzwell's Avatar
fitzwell
Painless Wiring just released part # 30812, duraspark wiring harness. Install that & be done with points & condenser. Also, replacement parts are readily available, even east plowshare Iowa
Old Sep 9, 2005 | 06:56 PM
baitmaster's Avatar
baitmaster
extra motor
Hey my buddy has carried a whole Toyota motor in his truck for 3 yrs. And it doesnt run. Anyway, my Petronix has been in for at least 8 yrs with no probs. I guess a guy should carry a whole diz for a spare?
Old Sep 9, 2005 | 07:24 PM
"Beemer Nut"
Na, just points and condenser in a small plastic box with cam lube, shim stock (.016") a small 12 volt lamp with pig tails and alligator clips to time the dizzy.
I made sure it can be done and it was under 10 minutes but the Allison unit has never failed going on 18 years.
.....=o&o>.....
Old Sep 10, 2005 | 02:42 AM
70blue's Avatar
70blue
Do you have any idea what the wire harness costs everything else that is need for the conversion can be had for less than 100 bucks at autozone.
Old Sep 10, 2005 | 02:54 AM
70blue's Avatar
70blue
here is a diagram for duraspark 2. I know you asked about changing back to points, but as fitzwell mentioned this is a conversion you might want to consider.
