Help Poor Fuel Economy
I never really paid much attention to my MPG until now when gas prices are going through the roof. I have a 03 f250 4x4 5.4 with 3.73 LS with normal size tires. I did the math and I am only getting about 8 MPG. I am not an agressive driver and keep my foot of the gas as much as possible and most of my driving is hiway. This MPG number seems really low. I have about 56000 miles on the vehicle and I am not sure if the fuel filter ever has been changed since I am not the original owner. I replaced the air filter but this did not help. Can you give me some suggestions or let me know if these MPG numbers are average?
Tryin changin out your fuel filter, clean air filter like ford390, keep your foot out of it (toughest obstacle to overcome), Try avoiding complete stops if you can, and when it's safe of course... it takes a lot of muscle to get something that heavy rolling again from a dead stop... I try my best to keep it between 40 and 50mph whenever possible as that's what I've found to be most economical... Obviously you can't do 40 on the highway and 50 in a school zone. just common sense stuff - anything you can think of that will save a little here or there, it all adds up in the end.
When I first got my truck with 39k on it, I was getting 12-13... Then I started doing these simple things and I've had I'd say the last 8 or so tanks calculating out to 15 or 15.5.
Good luck
Good luck
Good luck
Good luck
best thing for gas milage i did is put on a summit racing muffler. summit brand was 25 bucks then had it put on. haven't check the fuel milage becasue i'm not throught he full tank yet but as of right now i'm getting ready to hit the half mark have 195 miles on the tank so far!
what does everyone else get to the tank or before the fuel light comes on with a 29 gallon tank AND A 5.4?
my light has been going on at about 300 miles and i still have 4-5 gallons in it based on the refill amount.
Haha, I almost crapped my pants when you said 195 to a half tank and I assumed you had the same tank as me, 38 gal. I hit about 260 at half a tank and get 15-15.5 mpg. I just got home from work so I'm too lazy to do the math to compare our mileage based on your info, but off the top of my head... it sounds about average.
Mike makes a good point by saying that 8mpg is way too low. You may want to check to make sure:
1. Your hubs aren't engaged
2. No calipers are sticking
If a caliper is sticking, the rim will most likely be covered in brake dust and/or noticably warm. When mine stuck, after driving 10 miles, you could feel the heat with your hand from about a foot away... The rim gets hot to the touch. You could also jack the truck up and make sure the wheels spin freely. If you have manual hubs, it should have "FREE" and "LOCKED" written right on them. If you have the automatic... Try putting in 4x4, drive around the block, drop it back into 4x2 and back up a few feet. The other way, jack up the front and turn one wheel by hand, if the front axle turns with the wheel, the hub is engaged.
These two things are just things that popped into my head. Hubs because they decrease mileage substantially if engaged, and the caliper because I've been there.
I'd say start by jacking the truck up one end at a time and make sure everything turns freely and that the hubs aren't engaged
Let us know how you make out
hey another suggestion run some injecter cleaner through that thing and make sure you use 2 of them or dont fill up all the way because at most they treat like 20 gal
do a tuneup on it also if you havnt allready, if your plugs are all used up, dirty, not gapped right, stuff like that can kill fuel miles ecspecially in a big boy like these
That is about right for me too. I absolutely hate the truck I bought. It is slow, lacks any sort of power and gets horrible mileage. I resorted to using my 1989 Bronco II to tow my 12' flatbed trailer because it takes off better from a stop and uses about 30 gallons a mile less in fuel. I will never EVER recommend a 5.4L to anyone!
I am on the lookout for a PSD. Just sucks I have had this truck less than 3 months and wish I would have never bought it.
