Ruff idle
Old Sep 1, 2005 | 11:01 PM
dandy deke's Avatar
dandy deke
Ruff idle
93 F-150, 2x4, 302. I change trannys and ever since I have a ruff idle problem. When I start the truck it has a ruff idle and when I excellerate in park it gets worse. The problem seems to stay during excelleration when moving but does not seem to get worse, if that makes sense. I can not tell the problem is there when at cruising speed. ie 55+ miles per hour. But when I let up on the throttle as it idles down the problem is more prevelant. HELP!!!
Old Sep 1, 2005 | 11:35 PM
texans's Avatar
texans
im not an expert on tranys, but did you use the same trany it had before. could it be that the flywheel needs to be machiened. I have always had that done when I replace a tranny. mainly becasuse it is right there when you get the trany off. let me know what you think. good luck
