I've heard of something called a stock lift which is where you tihgten two bolts underneath the truck i was just wondering if someone knew what that is and if it causes any damage.
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
I've seen something called a Torsion Bar lift. I'm not entirely sure what it entails but if you poke around with the search function you mind find something. Good luck.
If your truck has torsion bars instead of coil springs then you can usually adjust it. By turning the adjuster bolts you can raise or lower the vehicle's height, but keep in mind this throws off your camber (and in turn) toe adjustment which will wear your tires quickly.
I don't recommend adjustment as it will increase ride harshness, and you'll only get maybe an inch or two increase. It also puts more pressure on the torsion bars, which makes them more likely to break.
If you must adjust it, definately get an alignment afterwards, however keep in mind it may not be possible to get your caber back into spec.
