roller rockers performance increase
Old Aug 31, 2005 | 08:29 PM
jesse1385's Avatar
jesse1385
Question roller rockers performance increase
I have a 86' F-150 4x4 that I just rebuilt a 92' 5.0L H.O and intalled in the truck. Edelbrock performer intake, 600cfm carb, heads milled and ported, bbk headers. I was wondering what kind of increase in performance would I actually recieve with roller rockers. Anything noticible? It may be a lifted truck with 33's but I still love to give those ricers a run for there money.
Old Aug 31, 2005 | 11:20 PM
TigerDan's Avatar
TigerDan
If adding the roller rockers was the only thing you did and didn't change the rocker arm ratio in the process, the performance increase would be relatively small. You probably wouldn't notice a lot of difference. They will free up the valve train a bit, reducing friction and heat and increasing longevity of valvetrain components.
Crane claims increases of 15-25 HP by bolting on their full-roller rockers, but that's with increasing the ratio from 1.6 to 1.7. I think they're being a touch optimistic.
Without changing the ratio I would expect gains more on the order of 5-10 HP. Maybe as much as 15 in some cases.
I'd still do it though, every little bit helps!
Old Sep 1, 2005 | 09:05 AM
jesse1385's Avatar
jesse1385
OK thanks TigerDan. I might as well go ahead and do it.
Old Sep 1, 2005 | 09:27 AM
Kemicalburns's Avatar
Kemicalburns
if you want to burn some ricers running that large of tire you should think about gears more then anything. at least 4.10's front/rear
Old Sep 1, 2005 | 11:29 AM
jesse1385's Avatar
jesse1385
I already have 4:11's. Dont expect to beat alot of them, but I love it when I do. I cant pass up a drag when a chevy pickup pulls up next to me either
Old Sep 1, 2005 | 05:39 PM
TigerDan's Avatar
TigerDan
If you can't run away from them, at least run over them! (Oops, did I just say that?)
Old Sep 2, 2005 | 08:47 AM
Kemicalburns
well in that case figure on some 1.7 cobra rockers . they are pedestal mount which is what you would need. they will wake up that cam for sure. might need new pushrods to though.
