73-79 only speaker location??
Old Aug 31, 2005 | 05:35 PM
busted knuckle's Avatar
busted knuckle
has any one ever put a sub between the tcase shifter and the dash??
i got 2 lighting audio 12s from a buddy and wanna try to get one to fit in there.
if it wont fit there where else will it fit in our beloved trucks?
Old Aug 31, 2005 | 05:55 PM
brown79's Avatar
brown79
behind the seat
Old Aug 31, 2005 | 06:54 PM
highboy's Avatar
highboy
He's got a 4x4, so most likely his gas tank is behind the seat. you could look into putting them under the seat
Old Aug 31, 2005 | 09:31 PM
busted knuckle
no gas tank is under bed
just wanted to keep behind the seat space open.
just wonderin if it was pos.
Old Aug 31, 2005 | 11:11 PM
MBBFord's Avatar
MBBFord
You could fit the 2 12s right behind the back seat right next to each other in th middle, and have some room left over on each side. A amp can fix under the seat too, but wouldn't be to to well ventalated.
Old Sep 3, 2005 | 11:50 AM
dakonthemountain's Avatar
dakonthemountain
I have a 10" sub in a rolled box behind my seat (you can see it in my gallery under the carpet replacement pictures) It still leaves a lot of room on each side.
Dak
Old Sep 3, 2005 | 12:18 PM
ivanribic's Avatar
ivanribic
If you ever decide to go to bucket seats I saw a pretty trick box built one time that fit between the seats and also functioned as a center console.
Old Sep 4, 2005 | 10:53 PM
bpatton74's Avatar
bpatton74
You could build a box, fiberglass the outside, put it in the front of your bed, and port it into the cab.
