Sponsored by: Real Truck
Chassis Lubrication Question
Old Aug 31, 2005 | 03:20 AM
dgludwig's Avatar
dgludwig
Just picked up my new SD/SC 4X4 and, after reading the "Scheduled Maintenance Guide", it appears that the only recommended chassis lubrication requirements is to "inspect and lubricate front axle shaft U-joints" every 15,000 miles. Am I missing anything here?
Old Aug 31, 2005 | 04:43 AM
dmp437's Avatar
dmp437
On my '99 and '03 there are grease points on the steering componets but that's it. Until the ball joints wear out and you replace them with Moog componets, but that's 75,000 miles from now.
Old Aug 31, 2005 | 08:06 AM
BFR250SD's Avatar
BFR250SD
You have like 6 or 7 grease fitting under there. All are on the steering linkage or front driveline.
Old Aug 31, 2005 | 11:40 AM
FortyFords's Avatar
FortyFords
I would add lubing the brake caliper slides to your schedule! this will keep your brakes lasting a little longer.
Rich
Old Sep 1, 2005 | 11:32 AM
RagenStienke's Avatar
RagenStienke
I can only find 4 grease zerks on my '03 f250. Is there a diagram/schematic somewhere to point all the zerks out?
Old Sep 2, 2005 | 12:50 AM
BFR250SD's Avatar
BFR250SD
I'm trying to think off hand: 1 on each front u-joint (2), 2 or 3 on the steering linkage (4/5), and I "think" there is one or two others. Just look everywhere that has a joint too it. Some are difficult to see. The only u-joints that have zerks is the front axle u-joints. None on the drive shafts or in the rear, that I could find.
Old Sep 2, 2005 | 07:02 PM
Munkey's Avatar
Munkey
BFR250SD,
Der what? Two on the u-joints? Are your joints aftermarket or am I totally missing something here?
Old Sep 2, 2005 | 10:29 PM
BFR250SD's Avatar
BFR250SD
No, one on each of the u-joints, not 2 each. Or are you saying that yours don't have them at all. Mine has a zerk on each.
Old Sep 3, 2005 | 03:34 AM
Munkey's Avatar
Munkey
Yeah, er, heh, brain fart, I meant one on each u-joint.
Nope, mine doesn't have 'em! I didn't know Ford finally paid attention and put zerks on the u-joints on the '04 models. . .lucky you!
Old Sep 3, 2005 | 05:05 AM
BFR250SD's Avatar
BFR250SD
Yup, had to grease them twice while I was home. Was havin' a little fun.
Old Sep 20, 2005 | 07:20 PM
Go Devil's Avatar
Go Devil
I have asked the dealer repeatedly to lube the chassis and they claim "that there is no need to as the system is sealed." I think this is a bunch of crap. I have a 4x4, how often do all the zerks listed in previous replies need to be greased and what grease should be used? I have 60,000 miles and do not have any problems, but do not want any as this is such a simple exercise, and good insurance.
Old Sep 20, 2005 | 08:04 PM
Beast12's Avatar
Beast12
On my vehicles I always grease it every oil change or three months...which ever comes first. Grease is cheap. Replacing parts is not.
-Matt
Old Sep 20, 2005 | 10:44 PM
BFR250SD's Avatar
BFR250SD
Like beast said, it's cheap insurance and takes all of 5 minutes to hit them. They are all easy to get at and the only ones you really have to get under the truck for is the ones on the u-joints (if your truck has them).
Old Sep 21, 2005 | 12:38 PM
Antacus's Avatar
Antacus
I have not yet looked myself but I am guessing for the front u-joints y'all are talkin about 4x4s only?
Old Sep 21, 2005 | 06:25 PM
Beast12's Avatar
Beast12
Yep. There are no front u-joints on a 2 wheel drive.
-Matt
