Major help here please
Old Aug 30, 2005 | 09:48 PM
RobPStroker's Avatar
RobPStroker
Question Major help here please
ok im building a woods monster i have a 77 f-250 2wheel drive with a 460 i also have 2 frames one is a 79 and one is ealrly 70's i really dont know specific year its has a dana 44 high pinion and 60 rear the 79 frame is in way better shape so i want to use that one.
Question 1. will the axles bolt up to the 79 frame?
Question 2. can i use the 460 motor mounts in the 2 wheel drive for the 4 wheel drive or will i have to get diffrent motor mounts?
Question 3. will all the body bolt on to the 79 frame?
Question 4. what is the biggest lift you can get for these years?
Any help would be appreciated starting it this weekend thanks guys!!!
Old Aug 30, 2005 | 09:56 PM
Mil1ion's Avatar
Mil1ion
Welcome to the site.
May I suggest titling the thread with the topic ?
This lets us know what to expect & helps other when searching for the topic.
This is mentioned in the Read First FAQ thread
2) The 460 MM's will fit in the 4x4.
You will need a rear sump oil pan & pump though.
1) If I remember correctly the frames are narrower on the 77.
What date was the 77 assembled ? (it's in the Vin# ..last 6 digits.)
3) see above
4) 6" without lengthening the driveshaft I think
Old Aug 30, 2005 | 10:15 PM
MBBFord's Avatar
MBBFord
1 axles should fit fine, you might have to move shock and spring mounts IF frame width is diff., but that would be it.
2 Just take the MM off and put them on the 4x4.
3 The body mounts might match up like Mil1ion said.
4 The highest comp. made lift is 9" for a F-150 and I think 4" for a F-250.
Like Mil1ion said 6" would be highest with out lengthening driveshafts, but if your shaft would be to short and longer yoke would fix that.
Bulwinkle's Avatar
Bulwinkle
when did the hipinion 44 come into ford I thought it was 78
Old Aug 30, 2005 | 10:17 PM
MBBFord's Avatar
MBBFord
I know it was there from the start of 73-79 for sure.
I'm not to familiar with the 72 and earlyer models, but it wouldn't suprise me if they were highpinions then too.
Old Aug 30, 2005 | 10:25 PM
RobPStroker
im really hoping i dont have to move the shock and spring mounts i dont really see why they would change them either but anyways guys thanks for your help
