Corrosion again!?
Old Aug 30, 2005 | 03:38 PM
swhite005's Avatar
swhite005
Corrosion again!?
I just replaced the battery cables in my 1991 Ford Explorer EB because the vehicle wouldn't start. Car has run fine since the replacement approx 2 months ago. Looked under the hood today and noticed a significant amount of greenish colored corrosion around the positive battery cable connector. What does this suggest? I'd hate to have to replace the cables again if I can prevent it now. By the way, this is the same cable that showed corrosion prior to the replacement. Should I replace the battery? I had Autozone test the battery before I replaced the cable and they said it was fine...don't know if that means anything or not! Help!?
Old Aug 30, 2005 | 09:11 PM
vicv's Avatar
vicv
Corrosion on the cable ends can be a sign of a failing battery. If the battery checks out okay you could buy the treated felt washers to try to stop the corrosion.
Old Aug 31, 2005 | 03:55 AM
marragtop's Avatar
marragtop
There is also an anti corrisve spray that comes in a can. Clean up the battery posts and cable ends and spray both. As an added measure add the felt washers. This should give you full protection for less than $10.
