Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
'05 Escape - brake problems
Old Aug 29, 2005 | 08:46 PM
bremen242's Avatar
bremen242
Seems like a problem with all escapes... however
my girlfriend bought a brand new '05 Escape. I noticed the brakes vibrating while braking. IE: warped rotors.
Now, it is bad enough that even she notices it.
Will the dealer cover this under warrantee or will they claim it is a 'wear' item and tell us to go pound sand??
it only has about 2000 miles on it.
We haven't ridden the brakes or anything, just seems like the rotors are too small for the vehicle....
Old Aug 30, 2005 | 10:31 AM
dwmiller438's Avatar
dwmiller438
Angry Warranty item
Bring 'er back in. Only 2k miles? Get it checked.
Old Sep 2, 2005 | 06:10 PM
bananaboat's Avatar
bananaboat
Normally they won't but with just 2k miles, they should. I've had other "wear" items fixed on vehicles when they were almost new.
Old Sep 2, 2005 | 09:28 PM
bremen242's Avatar
bremen242
They ended up 'turning' the rotors.. sounds like I'll be buying rotors in anoter 4K miles
Old Sep 3, 2005 | 08:58 AM
bananaboat's Avatar
bananaboat
Don't buy the OEM rotors, they're disposable on all Escapes since they'll wear out before the pads. For about $100 you can buy some decent Raybestos (or other brand) rotors that will last. I replaced them on my 02 Escape due to wear and I imagine the 05 Escape will be the same.
Old Sep 3, 2005 | 12:07 PM
bremen242's Avatar
bremen242
sounds good. does bendix still have good rotors?
Old Sep 4, 2005 | 10:19 AM
bananaboat's Avatar
bananaboat
Probably. I just happened to use Raybestos PG Plus rotors since they are commonly carried in local parts stores and you can compare prices. Bendixbrakes.com shows the cross reference numbers.
Old Sep 6, 2005 | 08:42 AM
BlueOval5.0's Avatar
BlueOval5.0
I am amazed that Ford has not fixed this problem. It has been 5 model years now. The OEM rotors suck, period. Every time you change the pads, you need to buy rotors. It is ridiculous.
As was suggested above, buy a better set made by Raybestos or Bendix and it should help fix the problem. At 2,000 miles, it is a complete joke to have to change rotors.
Come on Ford, do the right thing!
Old Sep 7, 2005 | 06:46 AM
DoctorCAD's Avatar
DoctorCAD
The rotors don't suck, they are designed to do exactly what they do. DOT regulates brakes on a vehicle, and rotors are now designed to the minimum allowed by law.
It's not a problem, it's a feature!
Old Sep 7, 2005 | 06:48 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Not neccesarily, some brakes are darn good standard - the Escape doesn't fall into that category.
I do believe there were different pads to stop brake run out.
Old Sep 7, 2005 | 08:47 PM
BlueOval5.0
If you call throw away rotors a feature, you must be on something. You can't even cut the damn things when you change the pads. I've never heard of such a thing. You don't find a problem with rotors going BEFORE pads are worn?
Old Sep 7, 2005 | 10:26 PM
BigF350's Avatar
BigF350
FTE Emeritus
Yes you do - on Escapes!!!
I think it is referred to as a feature, not a fault...
Old Sep 8, 2005 | 07:33 AM
EBTDM's Avatar
EBTDM
My '02 is on the original rotors and 2nd set of pads. Currently coming up on 70K miles . No problems beyond normal wear and tear. Only parts installed all fall under the consumable category, i.e. oil, filters, wipers, tires, brake pads, & etc . Whish you all good luck cause I may one day need to replace my featured rotors .
Old Sep 8, 2005 | 07:37 AM
BigF350's Avatar
BigF350
FTE Emeritus
Yep, some get good ones, some get bad ones...
I know of one Escape that had 3 sets (of rotors) in under 10k. I know of another that has travelled over 60k with only 1 set of pads.
Old Sep 9, 2005 | 06:49 AM
EBTDM's Avatar
EBTDM
Originally Posted by BigF350
............ I know of another that has travelled over 60k with only 1 set of pads.
Now you know of two .
