Ethanol
Old Aug 29, 2005 | 01:09 PM
Wolfdog's Avatar
Wolfdog
Ethanol
Hi,
With the soaring gas prices I was thinking (I bet I'm not the first one) is it possible to use Ethanol/Gas mix in my 5.4L Triton?
If Yes, what mods I need to do and what is the max ethanol %/gas% mixture?
Old Aug 29, 2005 | 02:06 PM
BLAZIN_STX's Avatar
BLAZIN_STX
Maybe this can help..
Read it on MSN, they have a list on the bottom of the site of the vehicles that can run it, not sure if there are others or not. Somewhere in here i read that it should be in our owners manuals, as well as on the FORD website (do a search on google too)
http://moneycentral.msn.com/content/Savinganddebt/Saveonacar/P125241.asp
If memory serves me right, there is a thread about this already if you wanna search for more info.
I know Ethanol is kinda hard to find. But way cheaper if you CAN run it!
Blazin.
Old Aug 29, 2005 | 02:54 PM
Wolfdog's Avatar
Wolfdog
Thanks for the links.
So my 2004 5.4L Triton is a not FFV. Does anybody is possible to do some mods and make it a FFV.
Old Aug 29, 2005 | 04:48 PM
knutson's Avatar
knutson
E-85 no way we don't have a flex fuel vehicle, however, you can run up to 10% ethanol as is provided in the state where i reside iowa-is the #1 producer of ethanol (soybeans)
Old Aug 29, 2005 | 08:44 PM
99F150's Avatar
99F150
Originally Posted by Wolfdog
Hi,
If your truck is set up the same as ours in the states, you can run up to 10% ethanol (Made from corn not soybeans). It has been documented that up to 30% will not harm your truck. What is the cost of gas for you? Here in South DAkota it ranges from $2.50 to $3.00 depending on grade and location.
Dan
Old Aug 30, 2005 | 12:12 AM
Wolfdog's Avatar
Wolfdog
Thanks for the info.
The gas prices are in Europe around 7.3 to 10USD/Gallon!!
