Power steering hose movement??
Old Aug 29, 2005 | 10:12 AM
EBSTEVE's Avatar
EBSTEVE
Last night I drove my 7.3 02 F350 for the first time with the gauges installed and I jumped on it a few times and when I got where I was going the inner fender well on the drivers side was coated with fluid.
It's leaking from the high pressure fitting from the pump to the hydroboost, so I pulled it apart and there is a nylon washer that I could not get on a Sunday. I made one out of a drain plug washer (harder than it sounds) but when I got it back together I noticed that the line moves when the wheels are moving. It seems odd to me that there is movement every time I moved the wheel so has anyone else noticed this?
Just for reference it's got 285's on it with a level kit.
Old Aug 30, 2005 | 11:33 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I've never noticed that. Aircraft hydraulic lines move all the time when the pressure hit them. I wouldn't worry too much as long as it isn't leaking and the movement doesn't cause it to rub/chaff on anything.
Old Aug 30, 2005 | 11:40 AM
WA.Ranger's Avatar
WA.Ranger
Almost every hydrulic line I've ever seen on any equipment moves/jumps when preasure is applied. I've never watched my PS hose, but it wouldn't surprise me.
Old Aug 30, 2005 | 01:38 PM
EBSTEVE's Avatar
EBSTEVE
I guess I was not clear with what I thought was the issue. What was happening is that the line was moving at the fitting, rotating the seat at the pump. I could not get a nylon washer and the one I made was weeping so I had to buy a new hose for $50 and the hose part still moves but not anywhere near what it was with the homemade washer and the seat area seems to be staying put, so I think the washer was creating the problem.
AlexD
1983 - 2012 Ranger & B-Series
Feb 5, 2012 10:01 AM
RANGER589
18
Jun 3, 2011 10:03 AM
d5332
1997 - 2003 F150
Nov 26, 2010 08:04 PM
SunBum
Aug 8, 2010 07:52 PM
dlruss
Sep 24, 2004 12:37 PM
