Sponsored by: Auxito
rear end moved. Axle
Old Aug 28, 2005 | 07:13 PM
shanesF150's Avatar
shanesF150
This is how it first happen. I was goin around a turn and i was not in drive and i gave it gas and then i slaped it into drive... dident mean to but it happen..
Then my steering was all messed up... and i new something was wrong so i
pulled over and i looked and you could see the blocks were not flush with
the axle.. So i lifted the truck and losend up the u-bolts wich did not seem to
be tight AT ALL.. n let things hang then i tightend it back up wich then my
steering was back to normal.
But today at a light i just got on it like i normaly do n the axle moved.. Like
my steering was out of alightment big time.. It wouldent pull one way but the
steering wheel was not in its normal spot.
I tightend the u-bolts up to 130 lb's when i did the tighting.. Im told even if
the u-bolts are lose the axle souldent move unless the center bolt broke..
Is the center bolt the only thing that would make this happen if it was
broken ?
Old Aug 31, 2005 | 06:28 PM
johnsonswamp's Avatar
johnsonswamp
If the U-bolts were already loose, it could have been enough of a shock on the pin to shear it off. Loosen the U-bolts and check the pins (and the notch/hole for them to make sure it hasn't egged out to bad), it they are fine, make sure they go into their 'notch'/hole when you tighten them back up, and this time apply some lock tight on the threads.
Old Aug 31, 2005 | 09:05 PM
shanesF150's Avatar
shanesF150
Well i found out my u-bolts bent... So i ordered new ones.. Hopefully this will fix my problem.
Old Oct 17, 2005 | 10:26 AM
skyjacked4x4's Avatar
skyjacked4x4
id still take a look at the pin... just putting u bolts on wont fix the problem
Old Oct 17, 2005 | 07:24 PM
GammaDriver's Avatar
GammaDriver
Sorry Gents,
We're talking about a pin -where- ? attached to the axle to center it in the blocks?
Old Oct 18, 2005 | 12:09 AM
shanesF150's Avatar
shanesF150
no my problem with the rearend moveing ended up that my axle tubes were moveing
