89 F250 Floor Panel???
Try www.broncograveyard.com, or any of the other sponsors, lmc truck..... How much of the floor is gone? I've seen this on so many of our era's trucks (mine included). I think that water gets in from the vent (d-side, next to the e-brake) and rots out that channel, usually all the way to the cab corner. If you repair it, I would clean out the bottom of that vent so that it doesn't happen to you again. Crap like leaves gets in there and blocks the hole at the bottom that water is supposed to exit out of. I'm also going to put a screen to cover the grille so leaves don't build up in there.
Anyway, good luck....
You're talking about the cowl just in front of the windshield, right? The only thing I would be concerned about is if the air that goes through there is also needed by your heater/blower (a/c?). I'm not sure about yours, being a '76. On the early '80s trucks, that cowl and and vent is only to get more fresh air into the cab (if desired).
