390 running problem
Old Aug 28, 2005 | 10:30 AM
sisu1a's Avatar
sisu1a
390 running problem
I have a 390 with newly reconditioned heads, new timing chain & sprockets, Holley 4 barrel, will idle @ 1000rpm, timing set 12btc, engine stalls when shifted into rev or drive. Often backfires with flame from carb. Any ideas?
Thanks
Sisu1a
Old Aug 28, 2005 | 08:23 PM
rusty70f100's Avatar
rusty70f100
Where do you have the vacuum advance plugged? Pull the vacuum hose off the distributor, plug it, and then set the timing.
Old Aug 28, 2005 | 10:26 PM
redhawkssh44's Avatar
redhawkssh44
Also try dropping the idle to 800 rpm. You don't have a four cylinder there.
Old Aug 28, 2005 | 11:41 PM
edsf100's Avatar
edsf100
timing? carb adjustments? My 390 was backfiring and it was the timing. set mine to 10 tdc with idle at 700. I also corrected allot of carb problems once I changed from a holley to a Edelbrock.
Old Aug 29, 2005 | 10:03 AM
discman's Avatar
discman
could be the distributor is a tooth off. Rmove the dist. and move rotor slightly to right or left and see if it improves. This happened to me and moving the dist. over a tooth, helped with backfiring through the carb.
Old Aug 31, 2005 | 04:58 AM
scamardo's Avatar
scamardo
Set the engine at tdc on compression stroke, pull the distributor cap and look at where the rotor is pointing. Should be aiming right at the #1 spark plug tower on the cap.
Old Aug 31, 2005 | 05:13 AM
ford390gashog's Avatar
ford390gashog
guys the timing is fine. its not 180 off. he just needs to set it to 8 btdc which can be done by just turning it counter clockwise. no need to pull the dizzy.
