Driveshaft
Old Aug 28, 2005 | 04:38 AM
comtech's Avatar
comtech
Driveshaft
Ok I have a 03 f250 sd cc .I have found a squeeking sound coming from the inside of the secondary driveshaft.I have worked on cars before but I never heard of the driveshaft itself making a noise.Special driveshaft? I checked all the U joints, bearings center support and the sound seems to coming from rear portion of the driveshaft. I know replacing the driveshaft will cure the problem but I would like to know what causes it. Anyone run across this kind of problem? Thanks for any help.
Old Aug 28, 2005 | 05:14 AM
Kwikkordead's Avatar
Kwikkordead
There's a spline inside the boot that needs to be lubed.
Old Aug 28, 2005 | 05:44 AM
comtech's Avatar
comtech
Well your never to old to learn something new. With everything needing "sepcial" lub or fluid ,is there a special lub for this or would a bearing grease be ok ?
Thanks again and thanks for the help
Old Aug 28, 2005 | 09:00 AM
sdpj's Avatar
sdpj
XG-8 grease is what i ordered from the stealership, i assume you can use regular grease but im kinda **** like that, 7 bucks for a little tube.
Old Aug 28, 2005 | 01:01 PM
kennedyford's Avatar
kennedyford
make sure you line the weights up when you reassemble or use a yellow crayola to put back together correctly...he he he I know
