Rebuilt engine wont start
Old Aug 27, 2005 | 03:44 PM
Peter94's Avatar
Peter94
I rebuilt my 302 in my 85 F150, I put in a crane cam and 24 lb/hr injectors. It still has the speed density system, but it should at least start. The only thing i'm getting is the occasional backfire through the Throttle body, or the Exhaust depending on what i do with the distributor, i cant seem to find anything that will make it start. This is how i timed it. I Lined up the timing mark on the harmonic balancer with the timing pointer, Then i removed the cap to the distributor and unbolted the distributor so i could move the rotor so it was hitting the #1 plug wire. And nothing. IT seems like it just wont fire when its lined up properly. If I start moving the distributor around it'll backfire, but wont start. HELP ME PLEASE. THere is one funny thing, when i was buying the plugs for the engine, the guy asked me if it was for a EFI or carb, and i told him EFI and he seemed like he didnt know what one he should grab, would it even make any difference? I pulled the #5 plug, and it's sparking just fine when its out of the engine.
I also suspected the heavier fuel injectors might be flooding it, so i unhooked the fuel pump shut off, and sprayd small amounts of gas down the TB and same thing, just backfires.
Old Aug 27, 2005 | 04:08 PM
Ford Truck Racer's Avatar
Ford Truck Racer
You may have the distubuter 180 off. I did this on my engine. Set it to the timing mark again and go to the companion cylinder 1 and 6. Did this on mine and it fired right up.
Old Aug 27, 2005 | 05:43 PM
53wa2fl's Avatar
53wa2fl
I would have to agree with FTR. You most likely have the dizzy 180 out. It is a common mistake, so dont feel bad. If the dizzy IS in fact installed correctly, you will have to check the fireing order of the camshaft and make sure you have your wires correct. The 302 and the 351W can both run the same cams, but they have different fireing orders, and the wires MUST be adjusted to compensate.
Old Aug 27, 2005 | 06:20 PM
Peter94's Avatar
Peter94
when can we set a date for marrige? I'm so happy right now no one could wipe this certain grin off my face!!!! I Love ford trucks and THANK GOD FOR FTE. I flipped it 180 and just hit the key and it sounded like a real engine again for a quick 2 seconds. I just about crapped myself when i heard the sound. So i flipped the key back and fourth between run and off to prime the fuel system a little more then started her and let her rip!!!!!!!!!!! Thanks so much!!!!!!!! Just kidding about the first sentance by the way. Thanks alot
FX4-350
38
Mar 26, 2014 08:46 AM
n4ynu1010
16
Aug 4, 2012 08:36 PM
futureislime
Aug 9, 2009 08:11 PM
jefster
Oct 3, 2004 04:54 PM
GuyWithAnOldFORD
May 8, 2003 08:51 PM
