Sponsored by: Real Truck
new user with an e-brake question
Old Aug 27, 2005 | 02:19 PM
elkarcher's Avatar
elkarcher
Cool new user with an e-brake question
I have a 2000 f-350 stroker with a problem. My e-brake light keeps coming on and I have to set the brake and pop it to get it to turn off. Its anoying the crap out of me. How do I adjust it? Any help is greatly appreciated.
Old Aug 27, 2005 | 03:25 PM
Beast12's Avatar
Beast12
Hi and welcome to FTE! Be sure to read this to help you around this site: https://www.ford-trucks.com/forums/s...d.php?t=300691 There are also State Chapters located near the bottom of the main forum page.
Thread moved to Super Duty forum. These guys should be able to help you.
See ya on the boards!
-Matt
Old Aug 27, 2005 | 11:45 PM
chiahunw's Avatar
chiahunw
double check your brake fluid level. if the brake fluid level is low, it will light up parking brake warning light.
Old Aug 29, 2005 | 02:13 AM
V10man's Avatar
V10man
The switch is on the e-brake. There is a rubber ****/bumper on the lever that pushes on the switch when in the released position. Either buy a new bumper or tape something on it to make it taller.
Old Aug 29, 2005 | 12:53 PM
elkarcher's Avatar
elkarcher
Thanks for the help. I will check those things out.
Old Aug 29, 2005 | 01:46 PM
Rongold's Avatar
Rongold
E-brake
Check to see if all the cables as well as the levers at each rear wheel are free. When the EB pedal does not return all the way, that is usually an indication that something is stuck. Spray all cables with penetrating oil and exercise the EB pedal a number of times to get the oil into the cables. If the cables afr free, but one of the EB levers at the rear wheels are not returning, you might have to remove the rear rotor at that location to free it up. If it is that, make sure that you coat the levers with anti-sieze grease to prevent it from happening again.
RON
