03 Explorer ?
Old Aug 26, 2005 | 02:20 PM
BP27's Avatar
BP27
03 Explorer ?
We own an 03 Explorer that is experiencing the following problem
Low speed or stationary noise/vibration at lower steering shaft area when turning. I found the tsb on this site, however, it doesn't say anything more than what I wrote above. I want to find out if others are having this problem-also did Ford fix it? Was it covered? etc.
Any help would be appreciated.
Old Aug 26, 2005 | 02:38 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
moved and member notified
