Modular V10 (6.8l)
Custom Y pipe help
Old Aug 26, 2005 | 01:09 PM
dansV10's Avatar
dansV10
Custom Y pipe help
For those of you who have done the custom Y pipe swap, what was the pipe material your shop used for the Y pipe you had fabbed? Shops I have spoken to indicate they would be using 14 gauge aluminized pipe for a Y pipe for me. How will this type of material hold up to the temps associated with the exhaust at the collecter location?
Any comments are greatly appreciated.
Dan
Old Aug 26, 2005 | 04:57 PM
NoMo's Avatar
NoMo
Aluminized pipe will work just fine. The aluminum heads will melt long before that steel-alloy pipe does.
Old Aug 26, 2005 | 10:56 PM
V10man's Avatar
V10man
Dan, you could try these:
http://www.magnaflow.com/02product/02hardware.asp
www.summitracing.com part # FLO-Y250300A
I'd use the Flowmaster one from summit.
Old Aug 29, 2005 | 01:34 PM
Richard2212's Avatar
Richard2212
DansV10,
Aluminized pipes are just fine. Have used several. I made my own from mandrel formed individual pieces. I got my Y transition from www.drgas.com.
My pix are in my gallery "Richard's Excursion".
Old Aug 29, 2005 | 01:43 PM
kenneBF250V10's Avatar
kenneBF250V10
Dan
Aluminized pipe will work just fine. Here is a picture of mine, I used the Flowmaster y-collector which makes for a nice neat exhaust.
Old Aug 29, 2005 | 02:36 PM
dansV10's Avatar
dansV10
Thanks guys!
I had a great opportunity to get a custom Y made up this weekend and I love it! It has made a difference in how the truck accelerates and how the engine seems to work "easier".
Pics in gallery.
Dan
Old Aug 29, 2005 | 05:06 PM
kelro's Avatar
kelro
Dan,
What did you do with the O2 sensors? can your exhaust man make another one?
Old Aug 29, 2005 | 05:27 PM
dansV10's Avatar
dansV10
The O2 sensors are still in place. The mechanic cut one tube off several inches below the pipe and welded a new piece on so there was no messing with the O2 sensor on that side at all. On the other side he installed a new pipe with a brand new sensor bung and threaded the sensor right in.
His words, "Piece of cake."
Can he make another one? You bet he will. PM me and I will give you his contact info.
Dan
Old Aug 29, 2005 | 09:24 PM
cwstanley's Avatar
cwstanley
Smile
Dan, I don't have the 'priviledge' of emailing other members yet so if you could drop me a line or whatever I'd be interested in that set up your guy did as well.
thanks
craig
Old Aug 29, 2005 | 10:09 PM
dansV10's Avatar
dansV10
cw,
PM'd you.
Dan
Old Aug 30, 2005 | 07:40 PM
vfrrick's Avatar
vfrrick
I found a shop that is going to change my Y pipe. But here is the story. Every shop I went to had never done one. At first everyone of them tried to talk me out of it. Stating that it was not necessary. Then I told them to get under it and take a look. They would come out and say I can do it for X number of dollars. Everyone tried to sell me a muffler, but I had already done that. The guy that is going to do it actually has a pre-fab y connector and was confident that it would make some difference after he looked at it anyway. I will keep you posted as to how it goes.
Old Aug 31, 2005 | 11:12 PM
vfrrick's Avatar
vfrrick
Well I got the pipe changed today. I can say that it sounds much different. It is deeper at idle but when the rpms come up in neutral you can hear it breath, sounds like under you feet. I don't k know if it is just more air hitting the converter or exactly what it is. I will let you know. As far as performance I have not had time to really tell but it feels like between 1500-2500 a little better response. Will keep you updated.
Old Sep 1, 2005 | 05:31 AM
dansV10's Avatar
dansV10
Congrats on the new Y! Have any pics?
Keep us informed on any changes in the truck's performance.
Dan
Old Sep 1, 2005 | 03:30 PM
SCHRADE's Avatar
SCHRADE
Vfrick did you have the flutter before and is it gone now?
Old Sep 1, 2005 | 04:15 PM
vfrrick's Avatar
vfrrick
I guess someone will have to define the "flutter". Before I had just the FM40 and at about just off idle and a little more it had this deafing rumble. I mean could not hardly hear the radio and things like that. Once you got throught that spot where either it would shift or you could come off the trottle to a different point it was ok. Now the more you get on it the more is sounds like those annoying hot rice burners when they go by you. That is from inside I don't know what it sounds like outside but I bet it is very close to the same.
With all that said I don't know but I would guess if it did not have it beore it does not. Very Annoying sound.
