10k mod need help
Old Aug 26, 2005 | 12:45 PM
raydar's Avatar
raydar
10k mod need help
I'm haveing trouble finding the icp. I have found a site that tells me how to do it with pics. When I opened my hood and looking at the pics the altinator is on the others side of the motor. I'm thinking it might be a little newer than mine. I have 96 psd can someone tell me where it is at and what is looks like. I have looked and all the sensors look the same to me. thanks
Old Aug 26, 2005 | 01:56 PM
rodolan's Avatar
rodolan
looking at the engine it's on the right hand side just to the right of fuel filter screwed into block right below valve cover, it has three wires coming from it, one wire i think is blue with green stripe and one is brown with stripe and the other i forget. I had 18k mod on my 95. Little more power no difference on fuel mileage..........
Old Sep 5, 2005 | 03:20 PM
raydar's Avatar
raydar
I must be blind I can not see anything below the valve cover.
Old Sep 5, 2005 | 05:23 PM
raydar's Avatar
raydar
I still can't find the thing is rodolan right? I'm I just not seeing it or is my 96 psd dif than a 95.
Old Sep 5, 2005 | 05:51 PM
FarmboyAC's Avatar
FarmboyAC
Its on the right side of the motor as your looking at it and its more like above the cover kind of in the V. Towards the front of the engine. hope this helps.
Old Sep 5, 2005 | 06:10 PM
raydar's Avatar
raydar
thanks for the replay farmboy I just wnet outside and pulled the a plastic cover of the top of the motor. I think I found it but not for sure. what i'm looking at is at the frount just to the left of a lifting eye and behind the ac. It has three wires blue with a green strip,white with red strip, brown with white stripe. Did I finally find or not please replay
Old Sep 5, 2005 | 08:29 PM
raydar's Avatar
raydar
still looking for help
Old Sep 5, 2005 | 08:31 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
according to rodolan, sounds like you got it. pull it out however it goes, and see if it is like the new one you have. (or if you are just checking location, disregard, i think you have it.)
Old Sep 6, 2005 | 03:52 PM
rodolan's Avatar
rodolan
Talking
Sorry I didn't explain better but it sounds like you've found it now......Rodney
