tick tick tick
Old Aug 26, 2005 | 09:55 AM
kwaskow's Avatar
kwaskow
tick tick tick
Starting to hear a valve ticking sound on my 99 Navigator. Should I switch oil brands, or composition to help?
Old Aug 26, 2005 | 10:12 AM
01silvergt's Avatar
01silvergt
Does the 99 Nav. have the DOHC or the SOHC, can not remember when they swaped in the Nav.'s?
Old Aug 26, 2005 | 10:39 AM
kwaskow's Avatar
kwaskow
DOHC, 4 valve.
Thanks
Old Aug 26, 2005 | 11:53 AM
TDN's Avatar
TDN
I think it was just the first year of the Nav (98) they had the SOHC 5.4L motor. 99-04 Nav's had the DOHC 32v InTech engine.
Old Aug 28, 2005 | 11:04 AM
Freak4Ford's Avatar
Freak4Ford
kwaskow, what brand of oil do you use now? What weight is the oil? Is the oil synthetic or dino oil?
Old Aug 29, 2005 | 10:25 AM
kwaskow's Avatar
kwaskow
Usually motorcraft, synthetic blend 5w30.
Old Aug 29, 2005 | 03:16 PM
XLTinRHODY's Avatar
XLTinRHODY
Not to put a scare into you but that sound has also been noticed by many who have gone on to blow out a spark plug. I certainly would check them to see if any have worked loose. Alittle bit of labor might save you big $$$. Good luck.
Old Aug 29, 2005 | 03:43 PM
ford390gashog's Avatar
ford390gashog
or a exhaust leak.
