77 ford help
Old Aug 26, 2005 | 09:23 AM
woodbutcher47200's Avatar
woodbutcher47200
77 ford help
Hi everyone it is nice to meet you all. my problem is i have a 77 ford F100 4.9L. The problem is i cant set the mixture on the carter yf carb. Whether i turn the screw in or out there is no difference in the way it runs. I hope someone knows the answer. Again nice meeting you all and thanks.
woodbutcher47200
Old Aug 26, 2005 | 10:06 AM
subford's Avatar
subford
You posed in the wrong forum, but anyway the screws do not make any difference in the way it runs, they work with the Idle only.
Old Aug 26, 2005 | 11:41 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
MOVED and meber notified
Old Aug 26, 2005 | 04:04 PM
yttrium_on_rye's Avatar
yttrium_on_rye
I also have a 77 ford F150 4.9L (190,000 miles on it) with the carter 1-bbl. Check to see if any of the mounting screws on the carb or the hold down nuts are loose. This is a very common problem with the carb. When I rebuilt mine, I used locktite on all of the screws and (knock on wood) haven't had any come loose yet! The loose screws or mounting nuts can cause a vacuum leak which will make your idle adjustment screw next to worthless. I would also check all of the vacuum lines and caps to make sure that you don't have a leak. The carter yf carb is somewhat temper mental but once you get it dialed in right it works good. I get 17 mpg in my truck and when I got my emissions check done last month the guy said my truck would have passed 2005 car standards. Hope this helps!!
JUGERNAUT
Jun 29, 2013 07:12 PM
woodbutcher85
Nov 12, 2011 11:16 AM
woodbutcher2
1978 - 1996 Big Bronco
Dec 20, 2004 03:41 AM
woodbutcher
Aftermarket Products
Jul 31, 2001 10:25 PM
woodbutcher
Mar 4, 2001 03:00 PM
