Random miss .Timing light same miss?
Old Sep 6, 2002 | 12:49 PM
strait6stick's Avatar
strait6stick
timing the engine I saw the light was missing also ?
truck still gets hot
1979 300 6
Reman napa 1978 bare bones carb
new wires,plugs"gaped",cap,rotor
I'm lost the recomended shop told me carb wrong $350 later runs worse
Old Sep 6, 2002 | 01:48 PM
dfisher1's Avatar
dfisher1
Strait6,
Does your vehicle miss all the time or just when its warmed up?
A random miss could be caused by many things:
1. Bad pickup stator in distributor.
2. Bad coil
3. Vacuum Leak
4. Bad plug wires or wires that run parallel jump spark.
A missing cylinder is usually not caused by a carb. When did this problem start? After a specific repair? After a rebuild? After an accident? Give me some details, please.
KingFisher
Old Sep 6, 2002 | 02:31 PM
strait6stick
[updated:LAST EDITED ON 06-Sep-02 AT 03:44 PM (EST)]Ran hot from day I got it.
replaced the origional plugs, wires,cap,rotor
checked the whole colling system.had the chemical test on the head gasket.
no vacume leaks.
no jumping sparkran in 100% darkness saw nothing. in 3000 miles havent boiled it but border line "pings hot-diesles shut off" oil clean but shot in 1000
My concerns
no vacume to disp during idle?
wants to stall from stop in 1st have to "feather the gas or rev@slip"
timing mark wanders under light.
I switched the carb does this affect timeing.
Only gets hot on the highway or over 60mph
misses when cold,hot, warm, day, night, timing 3-14 degres doesnt matter it misses and has even before said repairs in fact the repairs "amplified" the probs.
It has 86,000 one elderly owner miles and is other than paint perfect.
But I am going to blow it up the wife smashed the car and the cheroke lost its third member now the "project truck" is doing 150-200 miles a day and I'm lost as to the hot-running problem.
I'm about ready to sell it before I destroy a nice truck.Use the money to fix the others<sobbing>
Old Sep 6, 2002 | 02:40 PM
strait6stick
BTW I can see down the spark plug holes and see no crud-carbon I meen 0
NO cylinder wear ridge
but the walls and pistons blued good?
Old Sep 6, 2002 | 04:51 PM
tetraruby's Avatar
tetraruby
Regarding the heat problems, do you have an automatic or standard tranny?
Old Sep 6, 2002 | 05:43 PM
strait6stick
Its a stick
no ac
the radiator flows all the garden hose puts out which is a lot.
Its hot with out a termostat at all
One good point the heater works awsome
Old Sep 6, 2002 | 05:44 PM
strait6stick
BTW the anti freeze is at 30 bellow.
Old Sep 6, 2002 | 06:51 PM
araiderfan2001's Avatar
araiderfan2001
Do you have a fan shroud? They help!
How close is you're fan to the rad.? They make fan spacers to get the fan closer.
I've got a 77 F-100 w\302 and just bought a new 4 core radiator(stock was a 3 core). The radiator is bigger but there are bolts holes for it (I guess the big blocks com w\the 4 cores).
Anyway this did wonders for the operating temp! Sitting still for 30 min. on a 92deg. day it stays between 170 - 190 deg. My '95 Dodge Ram never runs under 205!
Old Sep 6, 2002 | 08:44 PM
Mike W's Avatar
Mike W
Put your plug wires on loose, just enough to make contact with the plugs. Lift them one at a time to see if the engine slows down. If one cylinder does not, that one is the problem. I have seen one new plug that was bad. Do a compression test and check the timing chain for slop. Take a good look at the distributor plate for wear that might cause the timing to vary.
Old Sep 6, 2002 | 10:42 PM
strait6stick
[updated:LAST EDITED ON 06-Sep-02 AT 11:44&nbsp;PM (EST)]This motor should have NO problem cooling the truck
3rd late 70s 6 stick truck I've owned.
the last had 1/3 of its cores sodered off pull 5000lbs from LA to minniapolis in aug!
The timeing is GEARED and low miles.
Distibutor plate ?
truck has power
smokes em good with no clutch dump.
Have and uninstaled
split headers
edelbrock 2bbl intake
1 ton granny 4 spd
3/4 ton springs
Goal
to pull a 1979 coachman Quinstar "the flagship model" 10,000lb 31'fifth
wheel I own and have never pulled<sad>
Have the 79 coachman pamphlet with my camper pulled buy a my 79 ford
on the cover <recreating the 70s camping experiance>
Old Sep 7, 2002 | 12:30 AM
tetraruby's Avatar
tetraruby
This one is wierd. A fan shroud will not help a six like an eight.
Old Sep 7, 2002 | 01:15 AM
strait6stick
I'm going to do the water pump in the am.
Could I modify the fan blades more push?
New radiator? mine looks mint out little crud inside.
I still think the miss is the hot prob.
How do I check the coil?
the disp assy?
Ignition mod?
Maybe carb mix lean"preset" gets good mpg
If I had the extra hondo this week I'd send it to ford to figure it out.
Old Sep 8, 2002 | 01:11 PM
strait6stick
^bump^
Impress me guys.
Old Sep 8, 2002 | 01:56 PM
Franklin2's Avatar
Franklin2
I would check in the dist. The plate moves back and forth, and the wiring inside the dist is made special so it will flex, but it still could be broken internally. The easiest way to try this is throw money at it and buy a rebuilt dist. Or else, take the guts out and take each individual wire between your fingers, and pull down the length of the wire to see if it's broken internally. Also check all the connections in the plugs going tothe coil and dist. The engine shaking back and forth could be pulling on them. Also, if the older carb worked better, put it back on.
Old Sep 11, 2002 | 03:56 PM
dfisher1's Avatar
dfisher1
Strait,
This sounds like the cam is advanced. Is it possible the timing gears are off a notch. If they were, you would have good torque and weak top end and the vehicle would run hot. Take a compression check and see what you got. The only way to check is to pull the timing cover and check the marks. This would explain the pinging also. i had a similiar sitiuation almost ten years ago. It cost me a bit of money because i lost the head gasket before I figured it out.
KingFisher
