What to do?
I added som pics of the engine to the gallery. ( make sure your shots are up to date first ) LOL
TailGater_73F100
Savannah, GA
TailGater_73F100
Savannah, GA
Would be interested in seeing those compression numbers.(dry and wet) posted here, if possible.
Use masking tape to number each of the plug wires to make re-install easier after. Also remember to pull the center coil wire on the coil side to avoid a surprize jolt should a plug wire head to ground.
I checked the pics in the gallery, even if it needs a rebuild, the truck looks clean enough to make it worth the effort.
The other guy that helped him hook up the plug wires incorrectly. I'm not sure how it was able to run as the #1 plug wire was hooked up to the #6 or #3 slot on the cap.
Thats where we stand for the time being. I should be able to install the new wires and run the compression check today.
Thanks
TailGater_73F100
SAvannah, GA
If you were to look at the top of the cap, the wires should be installed in a counter clock-wise direction(rotation of the rotor) in the following order. 1-5-4-2-6-3-7-8.
Looking at the engine from the front of the truck, the cylinders on the left bank are numbered front(grill) to rear(firewall) 1-2-3-4 and the right bank(front to rear) 5-6-7-8. That should make getting the wires installed in the proper order easy. Keep us posted.
It's true that the rotor itself may not point directly at the post inside the cap, but that's a timing related issue as to how much advance you're running, and whether or not the number 1 cylinder is at true TDC(top dead center) on compression stroke.
What if someone before him had dropped a new dizzy in and it wasnt the same as the old one and the #1 when the cap went on was in a different spot relevant to the old one?????
What would screw him up is if that or something else appropriate were the case and he put one to one when it was running fine before, and now has problems.
I saw a thread once where that was the scenario, and it went 5 pages with different people trying to help him and no one could figure it out, firing order was right. Just because the cap has a 1 on it, doesnt necessarily mean thats where #1 goes.
I just dropped a new dizzy in my 429 and that was the case, it WOULD NOT seat where the old one was, just the way the reman one was lined up when you clamped the cap on, wires were #1 cylinder to #1 on the cap on the old one, and now they are 2 over on the new one.
Thats all I was trying to point out, if its not like that now and firing correctly, leave it alone
Well after fighting for about 2hrs
with the whole mind set of "this truck shouldn't be running like this" I had to set aside what I knew was correct and was only able to get it running by wiring it up as 1-5-4-2-6-3-7-8 with the #1 wire starting on the #2 post. Still blows my mind but anyways... it still dont run just right but it's better.Was only able to check the #4 and #5 cylinders, both held 150psi. ( RAIN )
Not lookin to dark and the end of the tunnel after all. Now what should we do with our new found info?
Thanks
Tailgater_73F100
Savannah, GA
This place is the greatest
Thanks
Tailgater_73F100
Savannah, GA
As for the wires needing to be rotated one post over...
To me that would indicate worn distributor and drive gear, as well as a worn timing chain assembly(possibly jumped a tooth). Don't worry to much at this time.
If the compression readings all look good, here is my recommendation.
Since your buddy was looking for a few mild performance upgrades to begin with, a mild RV cam, lifters and push-rods(you may want to go with new valve rocker arms here too, or look at having the heads done too if vacuum readings are not good) new distributor(rebuilt should be fine, but take the numbers stamped into the side of it in to get a proper replacement).
If you do the cam, the timing chain assembly has to come off anyways, no point in putting the old one on. The stock units were slider chains with nylon gears, and they were horrible. A new set-up with steel gears and a double roller(pre-stressed) timing chain is only a few bucks more than the stock unit, and well worth the upgrade. If all of that doesn't put the timing into a correct state, you've got a wrong part somewhere, or something not installed right.
One thing to be wary of when installing "some" aftermarket timing assemblies. Some come with a "3" position option. The default(stock) timing position is marked with a stamp, the other three are options for running extreme cams, and other performance options. If you're not going past a mild RV cam, the "other" options should be ignored. All of this should bring your timing back into "spec".
Once again, since you're there. You'll have the intake manifold off for this, so you may as well replace it with a decent intake and small 4 barrel carb. You'll get many opinions on cams, carbs, intakes for choices.
What I generally run with is a decent dual plane intake(my preference is an Edelbrock Performer or the older Torker or TorkerII series, for a truck) A 600cfm off-road carb(will perform very well on the street, but also allows for off-angle roads very well too)
For cams, I prefer the Competition Cams dual plane 260/270 RV cam, it works well with any truck.
My own recommendation. Even if the vacuum readings show good. I'd at least rent a valve spring compression tool and remove the valves and springs, get the tension checked on all the springs, and replace the valve seals.
May as well also just buy a complete engine seal kit, as they are cheaper than buying individual gaskets, and come complete with head gaskets. Fel-Pro is a good brand, but there are other competant mfgr's out there too.
Once again, keep us posted on the compression values. Let's go from there first, before we get to much deeper into what options are available.
As stated before, the body looks pretty sweet on this truck, even a total re-build would be worth it, IMO.
Wouldn't you think that being 4 posts over is alittle far?
We are going to check out the rest of the copression values as soon as weather and boss permit ( shhh ). Also a vacuum test.
Also looks like we are going to be in need of a wiring harness at some point. Some of the wires to the distributor are cracked. But like we all say one thing at a time.
Thanks
TailGater_73F100
Savannah, GA
Anyhow, as for having #1 at a terminal other than #1, personally, I recognise that as not being a sign of a loose timing set or jumped chain, for it to be that far off, the engine would pretty well not run.
Normally, It's from someone trying to drop in the distributor, it not lining up with the oil pump drive, and instead of turning the engine over until it drops in, they keep moving the distributor around and re-dropping it until it goes in. To check for a loose/worn timing chain, the best way to do it is to pull the distributor cap off, put a socket and breaker bar on the crank, and turn the crank one way until the distributor starts to move, and then turn the crank the other way, there shouldn't be much play there, spec is 1/2" deflection in the chain, which doesn't translate into much movement of the crank before the cam starts to turn.
