2.9L rough idle when cold
Old Aug 25, 2005 | 08:40 PM
jdwitte's Avatar
jdwitte
87 ranger w/2.9 when the engine is cold it doesn't want to idle but once it warms up for about 5min or if you drive it down the road for about a 1/4 mile it will run fine. It seems to run rich when I start it because it lets out a puff of smoke as soon as it starts.
Old Aug 25, 2005 | 09:14 PM
TigerDan's Avatar
TigerDan
Have you tried to pull the codes? That's where I'd start.
Old Aug 26, 2005 | 08:24 AM
jdwitte's Avatar
jdwitte
when I check the codes everything comes back clear but since it only does it when its cold it may not have enough time to produce a code in the ECM.
Old Aug 26, 2005 | 10:08 AM
mrshorty's Avatar
mrshorty
Maybe it doesn't have time to trigger a code, or maybe it's something outside of the EEC-IV system. You mention a puff of smoke at start up as if it has excess fuel, I think I would check for gasoline in the vacuum line to the fuel pressure regulator. A common failure of the FPR is to develop a leak in the diaphragm that allows excess fuel into the intake. You may have a small enough leak that it only shows up at start up, and once it gets the excess fuel cleared out, it can keep up.
Old Aug 26, 2005 | 11:43 PM
jdwitte's Avatar
jdwitte
I have already replaced the fuel filter & regulator a few months ago. Could a Ignition control module cause this?
Old Aug 27, 2005 | 08:38 AM
mrshorty's Avatar
mrshorty
I suppose it's possible for the ICM to cause these symptoms, but it wouldn't be the usual symptoms of a bad TFI module. Have you tried cleaning the intake and IAC valve?
Old Aug 31, 2005 | 02:48 PM
Jharger's Avatar
Jharger
What color is the smoke. If it's bluish - it's oile burning off. Typical for an old motor to have oil leak past the valve seals when it is off.
Old Sep 9, 2005 | 02:53 PM
bforce's Avatar
bforce
ya thats what mine does, i blew the regulator a while ago and replaced it. Purged the vaccuum lines. Still that same old smoke.
Carl Tritch
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Aug 27, 2016 06:39 AM
santeeford
1983 - 2012 Ranger & B-Series
Nov 6, 2010 07:58 PM
timothy47129
Bronco II
Jul 9, 2006 08:48 PM
ztuck
Apr 4, 2006 11:07 AM
BroncoMike
Oct 11, 2005 06:35 PM
