351 exhaust
Old Aug 25, 2005 | 08:22 PM
soloistsl3's Avatar
soloistsl3
351 exhaust
Howdy,
I have A 1988 F-250....351W
left and right pipes run into A converter...two pipes in..one pipe out.
can I remove the converter, and add dual mufflers to the existing dual pipes?
My first 4-by with A computer..so what will this do to the O2 sensor?
And if I can(hopefully)...can I then scrap the smog pump?
thanks
Old Aug 25, 2005 | 09:49 PM
ark_firefighter's Avatar
ark_firefighter
have a 96 f-150 4x4, mine is set up similer, but my computer is a obd2 i believe, after the cats were taken off they made somewhat of a y pipe for mine, am running single pipe, and then just past the glasspacks it splits into duels. mine had an o2 sensor after the second cat and just ran a MIL (o2 sensor elemenator) to the rear sensor and runs fine, no check engine light or anything, better gas millage i believe as well.. you can get the MIL on ebay for around 9.00 compared to 30 on the website... but dont know about the smog stuff, dont think mine has it, not sure though...
Old Aug 26, 2005 | 01:21 AM
MemOrex's Avatar
MemOrex
Just leave the O2 sensor where it is. You can add mufflers to those pipes. Dual Exhaust I think some people run into problems removing smog pump. (ie, Computer spits out codes and engine runs crappy)
Old Aug 26, 2005 | 01:04 PM
soloistsl3's Avatar
soloistsl3
I forgot to mention, this is A california truck.
I've read these came with too cats...but only one as far as I can tell. the first one(cat) has the air tube into it, oxy sensor is right before it goes into the cat.
is inbetween the left and right pipes.
local muffler shop, informes me.take the sensor off...or remove cat...truck computer will almost stop the truck from running....hmmm...(D)
Old Aug 26, 2005 | 07:15 PM
ark_firefighter
I removed both of my cats and belive it runs better then it did with them on....lol i have an o2 before were my cats were and one after, and its not throwing any codes what so ever with them being gone. Had to run a MIL on the rear one, thats only becuse it was behind the cats.. you shouldnt have that problom. with it being an 88
Old Aug 26, 2005 | 09:21 PM
Saurian's Avatar
Saurian
Leave the O2 sensor in its small crossover and just weld pipe on from there. Mount the mufflers right after the cab (under the cab will give you resonance), and then run pipe out the back or wherever you would like. More pipe after the mufflers, the "better" it will sound is the concensus.
You can bypass the Air pump with a smaller belt, or replace it with an idler pully for like 80-100 bucks from some company, don't have the website anymore.
Old Aug 26, 2005 | 10:28 PM
soloistsl3's Avatar
soloistsl3
Thumbs up
Thanks!! Thats what I thought...I was just unsure what the computer would do...or think! I can unbolt the first(or the only) converter, and reattach if I have problems. I have A smaller belt already.
so the A.I.R. pipes going to the manifolds..can just be capped?
this california truck has alot of smog it don't need...wish i knew what could be scraped
Old Sep 15, 2005 | 12:49 AM
soloistsl3's Avatar
soloistsl3
[QUOTE=Saurian]Leave the O2 sensor in its small crossover and just weld pipe on from there. Mount the mufflers right after the cab (under the cab will give you resonance), and then run pipe out the back or wherever you would like. More pipe after the mufflers, the "better" it will sound is the concensus.
You can bypass the Air pump with a smaller belt, or replace it with an idler pully for like 80-100 bucks from some company, don't have the website anymore.[
/QUOTE]
Thanks...great info. having dual exhaust, to the converter, helps.
flowmaster has a dual inlet...dual outlet muffler..ahhhhhh..
the local muffler shop swears eleminating the cat...and smog pump..since they be attatched...will kill the truck. computer will go into limp mode...truck will limp home.
bull I say...I am doing it myself,bought pipe expander..we will see
cats clogging anyway...so why add high flow cat when you can throw the damn thing away! 30 extra ponies with flowmaster...15 more without smog pump...electric fan will gimmie more!!
Old Sep 15, 2005 | 05:28 PM
cjjeeper85's Avatar
cjjeeper85
I dought you will gain more than 2 hp by removing the smog pump unless the bearings are starting to sieze.
Old Sep 15, 2005 | 09:13 PM
kens64's Avatar
kens64
Hate to tell you, but getting 30HP with a Flowmaster isnt gonna happen. Or with any muffler for that matter. Dont believe the hype.
Old Sep 15, 2005 | 09:26 PM
cjjeeper85's Avatar
cjjeeper85
I was gona say that to but I didn't want to completly burst his bubble.
Old Sep 16, 2005 | 09:22 AM
soloistsl3's Avatar
soloistsl3
True,but I was hoping removing a clogging cat..would...FEEL like that much
If i leave the pump, what to do with the air tube that was attatched to the cat?
Old Sep 16, 2005 | 09:24 AM
MemOrex's Avatar
MemOrex
I left my trube just hangin there. It dont mess with nothing
Old Sep 16, 2005 | 01:39 PM
cjjeeper85's Avatar
cjjeeper85
The only reason I got rid of mine is because every time I hit a bump it would bang around and anoy the crap out of me.
Old Sep 16, 2005 | 08:08 PM
soloistsl3's Avatar
soloistsl3
Cool...does it pump air out the tube? irritating noise?
