will the crystal clear front head lights fit 1998 expedition?? Mine has the older lights i would like the crystal clear lights they are the same shape and everything just that they are crystal clear.
if by "crystal clear" you are referring to the type found on the harley davidson or lightning f-150 trucks, the answer is yes- as will the corners by the way. most everything will interchange late 97 to 02 across the expy f150 family.
Absolutely. I just installed the Lightning style headlights and clear daimond cut corners on my 98 EB. They look awesome and bolt right up, the only thing I should warn you about is the aiming of the headlights. It was a little tough to set the beam pattern, but thats probably because i have never done it before. Anyway Ill post pics of the finished product some time this weekend. check it out!
