Engine mount replacement
Old Sep 15, 2002 | 05:41 PM
dbarracuda's Avatar
dbarracuda
how hard is it to replace an engine mount on a 77 f1-50 w/400?
Partly what i need to know is can i safely jack the engine up with a floor jack?
thanks
David
Old Sep 15, 2002 | 07:09 PM
LxMan1's Avatar
LxMan1
It's very simple. One center bolt, and 2 that bolt to the block. You can safely jack the motor up with a floor jack and about a 1" piece of wood. Place it on the oil pan(twards the side of the bad mount) and slowly jack it up enough to get the mount out. Do NOT jack in the center of the pan , you may dent it up and and push it in the oil pick-up and block it off.
Old Sep 15, 2002 | 07:13 PM
Mil1ion's Avatar
Mil1ion
