bleeding problems
Old Aug 24, 2005 | 06:44 AM
gravedigger's Avatar
gravedigger
bleeding problems
I am working on my 95 F150 4.9 4speedo/d changed master cylender. I tried bleeding,both peedle and gravity, when I push in the clutch it stays in.
I am lost is there somthing inside that could have broke, or fallen out of place?
Old Aug 24, 2005 | 11:13 AM
ovalholic's Avatar
ovalholic
Did you do just the master? or the slave also? You could try to draw fluid thru it with a vaccum pump.
Old Aug 24, 2005 | 11:26 AM
andym's Avatar
andym
I'm assuming you mean 5 speed...
Even after all the air is out of the system, you have to pump the pedal about 5 to 10 times to build up pressure. Then it will work fine.
That would have gotten me too, but a mechanic friend of mine told me about it ahead of time.
Old Aug 24, 2005 | 11:50 AM
gravedigger
how would someone go about bleeding slave? when you open the bleed screw won't fluid run throug the whole system?
Old Aug 25, 2005 | 06:53 AM
stuart1's Avatar
stuart1
Bleed it using the same method as a brake system.
