deck height and related
Old Aug 24, 2005 | 05:52 AM
eby's Avatar
eby
hello all i am new here and just have a few questions i can't seem to find answers for searching the forum-
what is the deck height on the 300? Has it changed through the years? i ask because i have found pistons with a wide range of compression heights (1.56-1.778) made for the 300 but i can only find 6.23 in rods
i also can't find the valve dimentions, size of the face and length and width of the stem. any help would be much appreciated
i have had a hard time finding specs and numbers for the 300 online, if it weren't for searching this forum i would probably still not have much. just a suggestion but when the string is posted with performance mods it may be helpful to include a page with basic specs for the 300 as well, things like deck height, rocker arm ratios, wrist pin sizes, compresstion height, journal sizes. etc. the basic information you need to really plan out a motor before you try to build it. thanks
Old Aug 24, 2005 | 05:59 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 24, 2005 | 07:34 AM
jgetti's Avatar
jgetti
The standard deck height for the 300 is 10.00 inches, and to my knowledge that goes for all 300's.
