late model frame swap
can 4x4 frame be converted to 2wd? wanting to put old styling with modern
drive train. must be all FORD swap.
thanks,
dave
The easy answer is anybody can do anything with enough skill, equipment, patience & money, to pull it off. Having said that, what's the point of making a 4Wd late model with IRS into a 2Wd "one off" ? I mean SUVs are inbetween wanna-be vehicles that don't really do anything remarkably well except eat money & handle poorly, and on occasion roll over easily.
Why wouldn't you use a F Series Frame that nearly falls into place with a minimum of alteration & prep', yet delivers anything any late model SUV frame can deliver & more, with a greater durability, potential for better handling and performance. Yet what bolts into a "reasonably late model" SUV bolts into an older, more durable, truck style frame?
My Slick sits on a 79 F-150 frame it has tweaked suspension & power train. The last thing I have to consider is any SUV keeping up with me, anywhere anytime either in performance or economy. I also don't worry about rolling my Slick over. It corners flat, sticking like paint of a double line on a mountain road. It's FoMoCo from its' 460 to its' paint color. . FORD is even written across the tailgate so stuff I get ahead of has something to do while they try to keep up, or catch up. . . . .
My point is if you're contemplating doing the retro/ Upgrade, work, expense, outlay, et al why not do it so as to come out ahead, or better off than you were when you started. Ball joints, Control Arms,Coil Springs & frame flex are okay for an automobile I suppose, but for an integral bed or uni truck, as you call it, why wouldn't you prefer a truck based suspension & chassis system? Or am I missing something here?
IMHO SUVs are stuck between vehicles, they are not good trucks nor are they good cars. They are not long lived, they lack sophistication (generally speaking) to either perform well or run economically either. . . So where's the advantage in this proposed swap. . . . For a Tax shelter?. . . . . or maybe a write off ?
I would not go through all that to end up with SUV Running gear that was reduced from a marginal 4X4 set up it once was, to a "one off" 2Wd conversion. Obviously I'm against the Idea for several reasons, but I only went there because you asked.
I don't mean anything other than, I believe your proposal's not a worthwhile project, especially for an Integral Bed, Slick, Pick Up.
But hey man. . . . this is only my $.02 worth.
FBp
Welcome to FTE,
This is the meeting place for slick minded truck affecinados, there are plenty here, and probably some with an opinion different than mine above. But I'm giving you what I honeslty believe or know.
Anyway welcome to the site Man!
FBp
thanks for your input, interested in all pros & cons of this sort of project.
looking at building a cruiser instead of heavy muscle, but lightning
is a possibility.
any feedback in body mounts for f150 frame??
thanks again,
dave
still don't have truck at home yet, it does have 292 engine. don't know about tranny.
if tranny is auto, i would like to stay with this combo, what are your thoughts about
changing front axle and ft & rr brakes?
thanks again
dave
