Gasoline
Old Sep 14, 2002 | 02:11 AM
paul_and_ball's Avatar
paul_and_ball
Post Gasoline
Is it okay to run on unleaded gasoline? I was told that my truck was designed to run on leaded. Will this have an effect on my gas mileage? Is it okay for the engine/parts? Lead additive?
Thanks.
Old Sep 14, 2002 | 03:15 AM
Jermafenser's Avatar
Jermafenser
Gasoline
What year is your truck? Or the engine you've got in there...but since you're posting in 73-79 trucks, I am safe to assume to say yes, your pickup can run on unleaded just fine. If I recall correctly, 73-79 pickups were desgined to run on unleaded AND leaded.
Old Sep 14, 2002 | 07:59 PM
paul_and_ball
Post Gasoline
It is a 1976 F-150 with a 460 in it. Is leaded any better for the truck or is there any difference? Performance?
Old Sep 14, 2002 | 09:11 PM
Jermafenser
Gasoline
76.....yes, you will run unleaded just fine. '76 F-100s were required to have cats, hence the unleaded requirement. Does your '76 F150 has a cat? What is its GVW?
I don't know about performance, I wasn't here during the leaded era...but I think leaded gasoline had higher octane.
Old Sep 14, 2002 | 09:52 PM
Mike W's Avatar
Mike W
Gasoline
Lead was a way to boost the octane of the gas. If your engine doesn't ping, there is no need to use a higher grade. The lead also helped to prevent valve seat erosion.
Old Sep 16, 2002 | 08:19 PM
tellico racing's Avatar
tellico racing
Gasoline
> '76 F-100s were
I had a 77 F100 that had a tag on the tappet cover saying "non catalyst" on it.I dont recall if it required unleaded or not.
78 F150 4x4
429 CID
Dana 44 spooled Front,
9"Locked rear,
5:13 Gears
17/40/15 Gumbo monster mudders
18/39.5/15 Swamper Boggers
BIG,BAD,and UGLY.
Old Sep 16, 2002 | 08:44 PM
Jermafenser
Gasoline
Hmm, you sure? When the requirements of the cats in '75, the F100 had to be 'cat'd'...hence why the F150 was introducted.
What's the highest GVW on F100? Or the weight rating for cats/non-cats?
Old Sep 16, 2002 | 09:15 PM
F150Lariat79's Avatar
F150Lariat79
Gasoline
Telestar
15
Jun 10, 2016 06:50 PM
coley909
6.2L V8
Jun 5, 2016 11:00 PM
Ramiro3
New Member Introductions
Nov 6, 2015 07:02 AM
jwdenney2
2004 - 2008 F150
39
Jun 23, 2015 06:19 AM
LARIAT 85
Oil & Lubrication
Apr 23, 2010 10:50 AM
