rear axel identification help please
Old Aug 23, 2005 | 06:54 PM
backhoeken's Avatar
backhoeken
Going nuts - Well already there-
I need to replace the pinion seal and cannot identify what rear axel I have to by the replacement part. The truck is an 1989, F250, with a ZF trans. I cannot read the metal tag as part of it has broken off. The label on the door code say's axel 35
Can someone please point me in the right direction
Thanks
Ken
Old Aug 23, 2005 | 07:31 PM
andym's Avatar
andym
The axle is a sterling (aka Visteon) 10.25" axle with a 3.55:1 gear ratio, open differential.
Old Aug 23, 2005 | 08:33 PM
backhoeken's Avatar
backhoeken
Is it a full float or a semi float
Old Aug 24, 2005 | 12:24 AM
andym's Avatar
andym
Most likely it's the full floater. If your GVWR on the driver's door sticker is 8500 or more, it's the full floater. Lower than 8500 it's the semi floater. You can also look at the axle and tell right away. If you have a large chunk of metal sticking out from the center of the wheel about 6" it's a full floater. A semi float will be flush with the wheel.
Old Aug 24, 2005 | 09:37 PM
backhoeken's Avatar
backhoeken
Thank you for the help
Outlaw56
19
Sep 8, 2013 06:50 PM
idesign
Mar 18, 2011 11:01 AM
imlost
1997 - 2003 F150
Aug 26, 2010 09:04 PM
njeske
1983 - 2012 Ranger & B-Series
May 6, 2007 03:57 PM
