I have decided to run waterless coolant in my radiator.
My question is , is any coolant that is not mark 50/50 or premixed waterless? or do they just have less water?
I was a little confused at the auto parts store cause I never ran waterless or even heard about it until I started search for a f350
I would recommend always running a 50/50 mix. I forget the explaination, but I think it has to do with the water being a better conductor of heat. the anti-freeze or anti-boil is more to control what the water is not supposed to do i.e freeze or boil. When purchasing anti-freeze, if it doesn't say 50/50 mix, then you'll have to add water. I personally refer to the 50/50 mix as emergency roadside refill.
Thanks in advance
If you're talking about Evans NPG+...you won't find it in the parts store. Need to find an Evans dealer. All of the coolants in the local chain auto parts stores require water, with the exception being the pre-mixed.
